I wanted to enable remote access to my HA instance and I thought Cloudflared might work for this.
As I use docker, I was thinking it would be easiest to just use it.
version: "3.8"
services:
homeassistant:
container_name: homeassistant
image: ghcr.io/home-assistant/home-assistant:stable
volumes:
- /home/xxx/docker/homeassistant/homeassistant_config:/config
restart: unless-stopped
environment:
- TZ=Europe/Stockholm
network_mode: host
ports:
- 8123:8123
version: "3.8"
services:
cloudflared:
image: cloudflare/cloudflared:latest
container_name: cloudflared
command: tunnel run
environment:
- TUNNEL_TOKEN=xxx
I modified my configuration.yaml to allow proxy calls:
# Allows proxy traffic from cloudflared
http:
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
My cloudflared container successfully connect to clouflare and is shown up as healthy. However, when I access my domain, https://name.fi/, cloud flare says host is having issues:
When I check logs on the cloudflare container, it says it cannot connect:
Anyone done the same? Any suggestions?
I followed these videos:
