I have installed kiosk mode by following the instructions on the git page. But, now I’m stuck, tried editing the configuration.yaml but it didn’t like the lines I put it. Can someone eli5 what I need to do to enable kiosk mode?
Open up the dashboard you want to work with, and in the upper right hand corner you’ll see 3 dots…
Edit Dashboard >> Then you’ll see 3 more dots …
Got it, thanks for the help. Had no idea that menu was there.
