Hey,
can i configure this device (http://docs.openhab.org/addons/bindings/silvercrestwifisocket/readme.html) in hassio? if I can, could anyone show me how?
Hey,
Hi I also want to solve this. Did you found some solution? Can you share please? Thx Jan
No news regarding this topic? I was the creator of the binding for openhab, but i dont have knowledge on Python and homeassistant architecture to immediately develop this integration. I can help giving knowledge how this binding works on openhab from scratch.
I know it’s an old thread, but it’s the only Home Assistant thread I’ve found for these old Wi-Fi sockets.
The code to make this work (from your configuration.yaml) is below - it’s built as a linux command so you might need to install some tools (sed, xargs, netcat).
The first command echo’s the ‘switch on / off’ command and is the most complicated bit - you need to put in your switch’s MAC address here
echo '0142{Your SWS-A1 MAC Address Here}104CF75F5A28A181574AC1B563CD51A78D'
Then sed converts the string from hex to bin
sed 's/\([0-9A-F]\{2\}\)/\\\\\\x\1/gI' $1
Next xargs sorts out the output so it’s something we can use
xargs printf
Finally netcat sends the command to the SWS-A1
nc -u {Your SWS-A1 IP Address} 8530 -w1
So putting the whole lot together into Home Assistant’s config :
# Add Lidl SWS-A1 Switch Control
switch:
- platform: command_line
switches:
sws_a1:
command_on: echo '0142ACCF2334ABCD104CF75F5A28A181574AC1B563CD51A78D' | sed 's/\([0-9A-F]\{2\}\)/\\\\\\x\1/gI' $1 | xargs printf | nc -u 192.168.1.100 8530 -w1
command_off: echo '0142ACCF2334ABCD10F7B4E74B970D96F3CA2BB5D3CD1C19D0' | sed 's/\([0-9A-F]\{2\}\)/\\\\\\x\1/gI' $1 | xargs printf | nc -u 192.168.1.100 8530 -w1
friendly_name: SWS-A1 Socket
Hope this helps someone and keeps these old switches out of the bin
Ric
Thank you very much for your information! I have been able to recover, I think it was my first Wi-Fi plug from many years ago, that’s where it all started and I can’t stop :).
They no longer gave service and that only served to paperweight, damn programmed obsolescence.
Great work, genius!
