Good day,
suddenly my stmp integrations do no longer work, got following Logs. Does anybody know what to do to
overcome this? Thanks in advance !!
JJ
Error setting up platform smtp
File “/usr/local/lib/python3.10/smtplib.py”, line 398, in getreply
line = self.file.readline(_MAXLINE + 1)
File “/usr/local/lib/python3.10/socket.py”, line 705, in readinto
return self._sock.recv_into(b)
TimeoutError: timed out
File “/usr/src/homeassistant/homeassistant/components/notify/legacy.py”, line 71, in async_setup_platform
notify_service = await hass.async_add_executor_job(
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 92, in get_service
if mail_service.connection_is_valid():
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 154, in connection_is_valid
server = self.connect()
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 140, in connect
mail = smtplib.SMTP(self._server, self._port, timeout=self._timeout)
File “/usr/local/lib/python3.10/smtplib.py”, line 255, in init
(code, msg) = self.connect(host, port)
File “/usr/local/lib/python3.10/smtplib.py”, line 343, in connect
(code, msg) = self.getreply()
File “/usr/local/lib/python3.10/smtplib.py”, line 401, in getreply
raise SMTPServerDisconnected("Connection unexpectedly closed: "
smtplib.SMTPServerDisconnected: Connection unexpectedly closed: timed out
