I have a couple Monoprice Recessed Zwave Door sensors. They only give you a value of “22” or “23” when opening/closing. I have this currently on (3) of my doors and am attempting to create a group template and sensor that will change based on those two numbers. “22” means open and "23 means closed. I have something similar for all my windows that works perfectly but their binary_sensor output is correct with on/off. Any help is appreciated!
Here is what I have tried and neither works group or sensor template works:
No luck on that. Both group.doors_2 and sensor.open_doors_2 values are either “unknown” or “0” and do not change when opening/closing the door. The sensor.patio_door_sensor changes from 22/23 depending on state.
My whole zwave network just took a dump, so I took the opportunity to upgrade to the new OpenZwave (beta) integration. I mention this because the sensors come up automatically as proper binary door/tamper sensors without any additional configuration or templating. Might be worth taking the jump if you haven’t yet.
