Been using this addon for a while now after finding it as the result of an upgrade that locked me out. Snapshot restored and issues resolved.
Now I check before each update. There has only ever been a couple of errors and reading through the breaking changes I have managed to fix the issues.
Just run the check for the update from 0.91.4 to 0.92.0 and I have a lot of error and even reading through the breaking changes can seem to see what the issue is.
Noting it still give the no errors mesage when checking against 0.91.4
It even look like the log may not be showing everything.
Before I start commenting out blocks of yaml and slowly putting back to find the issues.
Is a copy of the log saved anywhere? So I can see if the display is compleate.
Can anyone look at the log below and give me a pointer.
- data: [source /tmp/config/scripts.yaml:113]
activity: 30874467
entity_id: remote.lounge
service: remote.turn_on
watch_tv: [source /tmp/config/scripts.yaml:80]
sequence: [source /tmp/config/scripts.yaml:81]
- data: [source /tmp/config/scripts.yaml:84]
activity: 30785533
speedtestdotnet: ?
sun: ?
switch: [source /tmp/config/configuration.yaml:597]
- platform: mqtt
command_topic: cmnd/caravaninput/POWER
payload_off: OFF
payload_on: ON
qos: 1
retain: True
state_topic: stat/caravaninput/POWER
- platform: mqtt
command_topic: cmnd/stairrail/POWER1
name: Stair Button 1
payload_off: OFF
payload_on: ON
qos: 1
retain: True
state_topic: stat/stairrail/POWER1
- platform: mqtt
command_topic: cmnd/stairrail/POWER2
name: Stair Button 2
payload_off: OFF
payload_on: ON
qos: 1
retain: True
state_topic: stat/stairrail/POWER2
- platform: mqtt
command_topic: cmnd/caravandehumidifier/POWER
name: Caravan Dehumidifyer
payload_off: OFF
payload_on: ON
qos: 1
retain: True
state_topic: stat/caravandehumidifier/POWER
- platform: mqtt
command_topic: cmnd/Garage/POWER2
payload_off: OFF
payload_on: ON
qos: 1
retain: True
state_topic: stat/Garage/POWER2
- platform: broadlink
friendly_name: Conservatory Remote
host: 192.168.1.240
mac: 78:0F:77:D8:F1:4B
switches: [source /tmp/config/configuration.yaml:652]
conservatory_fan_hi: [source /tmp/config/configuration.yaml:661]
command_off: JgCcACsMLAwPKBAoDygQKA8oLAwPKBAoDygQAAEFLAwsDA8oECcQKBAnECgrDQ8oECcQKBAAAQUsDCsNDygQJxAoECcQKCsNDygQJxAoEAABBSwMKwwQKA8oECgPKBAoKwwQKA8oECgPAAEGKw0rDBAnECgQJxAoECcsDBAnECgQJxAAAQYrDSsMDygQKBAnECgQJywMECcQKBAnEAANBQAAAAAAAAAAAAAAAA==
command_on: JgBiACkOKQ8OKQ4qDSoNKw0qDioOKQ4qDygq6ysNKg4OKQ4pDykOKRAoDygPKQ4pDykq6ysNKg4OKQ4pDykOKRAoDygQKA8oECgr6isNKwwQKA8oECgPKBAoDygQKA8oECgrAA0FAAAAAAAA
friendly_name: Conservatory Fan Hi
conservatory_fan_low: [source /tmp/config/configuration.yaml:669]
command_on: JgCSACwMKw0PKA8oECgrDBAoDygQKA8oLAwr6iwMKwwQKA8oECgrDBAoDygQKA8oLAwr6SwNKwwQJxAoECcsDBAnECgQJxAoKw0r6isNKwwQJxAoECcsDA8oECgQJxAoKwws6isMLAwPKBAoDygsDA8oECgPKBAoKwws6SwMKw0PKBAnECgrDQ8oECcQKBAnLAwrAA0FAAAAAAAA
friendly_name: Conservatory Fan Low
conservatory_fan_med: [source /tmp/config/configuration.yaml:665]
command_on: JgCcACkPKA8NKw0qDSoOKg0qDioNKikPDSoOAAEIKQ8oDw0qDioNKg4qDSoOKg0qKQ4OKg4AAQgpDikPDSoNKw0qDioNKg0rDSopDw0qDQABCSgPKQ8NKg0rDSoNKw0qDSoOKikODioNAAEIKQ8pDw0qDSoOKg0qDioNKg4qKQ8MKw0AAQgpDykODSsNKg0rDSoOKg0qDSspDg0rDQANBQAAAAAAAAAAAAAAAA==
friendly_name: Conservatory Fan Med
conservatory_light: [source /tmp/config/configuration.yaml:657]
command_off: JgDQACwMKw0PKBAoDygQKA8oECgrDBAoDygQAAEFLAwrDBAoECcQKBAnECgQJywMECcQKA8AAQYsDCsMECgPKBAoDygQKA8oLAwPKBAoDwABBiwMKwwQKA8oECgPKBAoDygsDA8oECgPAAEGKw0rDBAoDygQKA8oECgPKCsNDygQKA8AAQYrDCwMECcQKBAnECgPKBAoKwwQKA8oEAABBisMLAwPKBAoDygQKA8oECgrDBAoDygQAAEGKwwsDA8oECgPKBAoDygQKCsMECgPKBAADQUAAAAAAAAAAA==
command_on: JgDQACwMKw0PKBAoDygQKA8oECgrDBAoDygQAAEFLAwrDBAoECcQKBAnECgQJywMECcQKA8AAQYsDCsMECgPKBAoDygQKA8oLAwPKBAoDwABBiwMKwwQKA8oECgPKBAoDygsDA8oECgPAAEGKw0rDBAoDygQKA8oECgPKCsNDygQKA8AAQYrDCwMECcQKBAnECgPKBAoKwwQKA8oEAABBisMLAwPKBAoDygQKA8oECgrDBAoDygQAAEGKwwsDA8oECgPKBAoDygQKCsMECgPKBAADQUAAAAAAAAAAA==
friendly_name: Conservatory Light
conservatory_tv_power: [source /tmp/config/configuration.yaml:653]
command_off: JgAaABweOR4bHhwdHB4dHRw6HhsdHR0dOTocAA0FAAAAAAAAAAAAAAAAAAA=
command_on: JgAcAB0dHB44HhweGx4cHR06HB0cHhwdHB8bHhwADQUAAAAAAAAAAAAAAAA=
friendly_name: Conservatory Tv
timeout: 15
friendly_name: Bedroom Remote
host: 192.168.1.244
mac: 78:0F:77:D9:0D:B9
switches: [source /tmp/config/configuration.yaml:682]
bedroom_tv_power: [source /tmp/config/configuration.yaml:683]
friendly_name: Bedroom Tv
timeout: 15
timer: [source /tmp/config/configuration.yaml:438]
alarm_entry_delay: [source /tmp/config/configuration.yaml:443]
duration: 00:02:00
alarm_exit_delay: [source /tmp/config/configuration.yaml:439]
duration: 00:05:00
updater: ?
Successful config (partial)
tts:
