Help understanding log file
I wonder if someone can help me understand the log file I’m getting and what I shall look more into. From what I know right know the only thing not working is the Arlo component. I would like to solve that, besides from that all stuff that I am using seems to work fine.
Running it all on Hassio on a PI3.
2018-08-07 18:57:02 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-08-07 18:57:10 ERROR (MainThread) [homeassistant.setup] Setup failed for arlo: Component failed to initialize.
2018-08-07 18:57:10 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of alarm_control_panel.arlo. Setup failed for dependencies: arlo
2018-08-07 18:57:10 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform alarm_control_panel.arlo: Could not setup all dependencies.
2018-08-07 19:24:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-07 20:22:48 WARNING (SyncWorker_7) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-07 23:21:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
File “uvloop/handles/stream.pyx”, line 609, in uvloop.loop.UVStream._on_eof
File “uvloop/sslproto.pyx”, line 171, in uvloop.loop._SSLPipe.feed_ssldata
File “/usr/local/lib/python3.6/ssl.py”, line 689, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2018-08-07 23:21:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
File “uvloop/sslproto.pyx”, line 504, in uvloop.loop.SSLProtocol.data_received
File “uvloop/sslproto.pyx”, line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-08-07 23:21:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-07 23:29:43 ERROR (SyncWorker_0) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 04:27:24 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:841)
2018-08-08 04:27:24 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: WRONG_VERSION_NUMBER
2018-08-08 04:27:25 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: NO_SHARED_CIPHER] no shared cipher (_ssl.c:841)
2018-08-08 04:27:25 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: NO_SHARED_CIPHER
2018-08-08 04:27:27 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: UNEXPECTED_RECORD
File “uvloop/sslproto.pyx”, line 182, in uvloop.loop._SSLPipe.feed_ssldata
File “/usr/local/lib/python3.6/ssl.py”, line 633, in read
v = self._sslobj.read(len)
ssl.SSLError: [SSL: UNEXPECTED_RECORD] unexpected record (_ssl.c:2281)
2018-08-08 04:27:29 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 04:27:32 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-08-08 04:27:32 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: NO_SHARED_CIPHER
2018-08-08 04:27:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 04:31:29 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-08-08 04:31:30 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-08-08 04:31:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 07:37:50 WARNING (SyncWorker_17) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-08 08:12:55 WARNING (SyncWorker_12) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-08 08:48:02 WARNING (SyncWorker_3) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-08 08:54:18 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 08:56:45 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
ssl.SSLError: [SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:841)
2018-08-08 08:56:45 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: UNKNOWN_PROTOCOL
2018-08-08 08:57:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 08:58:18 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-08-08 08:58:18 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-08-08 08:58:26 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 09:22:37 WARNING (SyncWorker_3) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-08 09:54:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-08-08 09:57:34 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-08 09:57:41 WARNING (SyncWorker_16) [homeassistant.components.switch.tplink] Could not read state for HallPlug: Communication error
2018-08-08 09:58:36 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-08 10:41:45 ERROR (MainThread) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
My log file looks like yours. I have found a topic at Github that I follow:
https://github.com/home-assistant/home-assistant/issues/15579#
I have read this item in github now, but it is closed for comments and I did not found a solution for the issue there.
If so many users have the same issue: do they live with this issues or is there a solution?
My hassio is very fresh (3 days ago) on a new raspberry pi 3+, I followed all the instructions, it worked fine until I enabled the remote access using duckdns as described in the documentation. And I am really not a specialist for SSL and related stuff.
if duckdns is the problem:
can or should I disable SSL until there is a solution for the issue? How?
I have the same problem, and I want to use Google Assistant, in the documentation it specifically says you need to have SSL set up… :frowning:
