Help Undestanding Location and Zones
I’m having trouble understanding why my trackers aren’t working correctly. I’ve setup 2 different zones, Home and Work in HA and then activated the location sensors inside my smartphone companion app. Location permission are also correctly setup for Companion App, but the tracker always stays on “Away” and no GPS coordinates are shown inside the tracker entity attribute. Then I setup Google Maps integration, tried both with the official integration and with custom HACS integration, both give me back the correct coordinates is I go to check the GPS location in the tracker attributes and they are the same that I’ve setup as my Home zone, but still the entity tracker is marked as Away. Yesterday for about an hour, was set correctly to Home, then moved again to Away even if I didn’t move from home.
What can I check to try to understand where the problem is? The radius are set up the 250mt for both home and work zones and the accuracy given back by Google Maps Integration is like 15-20 so I don’t think could be that either.
Thanks in advance
