Help w my understanding of pulse_meter.set_total_pulses (Flow Meter/Pulse Meter)
Hey.
Can someone help me with my understanding of this and why my - pulse_meter.set_total_pulses doesnt seem to work
button:
    on_press:
      - pulse_meter.set_total_pulses:
        value: 0
  - platform: pulse_meter
    unit_of_measurement: 'L'
    state_class: measurement
    icon: mdi:flash-outline
    accuracy_decimals: 2
    pin:
      number: GPIO13
      mode:
        input: true
        pullup: true
    total:
      state_class: total_increasing
      filters:
      - lambda: return x * (1.0 / id(select_pulse_rate).state);
Neither flow_meter_total_litres_3 or flow_meter_total_consumption_3 reset when the button is pushed. So im obviously missing something very fundamental.
Thx
It looks like you are missing the then: statement in the button code, and there are some indent mistakes as well. See: (Re)Setting the total pulse count.
Try this:
button:
    on_press:
      then:
            value: 0
    pin:
      number: GPIO13
      mode:
        input: true
        pullup: true
    total:
      filters:
Hey Thanks Ed.
I knew it would be something as stupid as that.
The indents were just a ramification of losing them to “cut and paste” from the UI to the forum.
The only part that doesnt seem to work is that when the button is pressed, the sensor gets reset, but does not send an update to HA on the new value until the ACTUAL sensor changes (GPIO13) at which point the count starts at 0.
Do you know of any way of updating the sensor when the button is pushed. I have tried force_update: true in the sensor config to no avail.
I am not sure it will work, but did you already try to add the timeout option?
This defaults to 5 minutes when not set specifically, so does the sensor reset to zero 5 minutes after pressing the button, or not at all?
If it does you can try to set it to a short time.
