I stupidly deleted my backups thinking everything was working in my system, as I’d finally gotten my Z-wave dongle, Skyconnect, Z2M and multiprotocol working - then I stupidly decided to update the firmware on the Skyconnect and there have been some recentl updates to both addons so I’m getting tripped up.
Is there a repository and method availble to access and restore older versions in a case like this? I presume I could duplicate my backup and replace versions in the clone with the needed versions if I could get them, then do a partial restore (I don’t mind recreating my 5-6 Zigbee devices).
I tried going back to 7.3.2 and it failed, though it worked fine to update me to 7.4 earlier so I guess maybe something won’t allow it. That said I tried to reflash 7.4 and it wouldn’t allow that either.
I re-read your message from earlier and realized I do have the Google Drive backup addon. It had a backup with the 2.3.2 multiprotocol addon, but unfortunately Z2M was still 1.3.5-01 and I’m still getting errors. Going to post the log as an issue on Github I guess.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
Add-on: Silicon Labs Flasher
Silicon Labs firmware flasher add-on
Add-on version: 0.2.0
You are running the latest version of this add-on.
System: Home Assistant OS 11.3 (amd64 / qemux86-64)
Home Assistant Core: 2024.1.2
Home Assistant Supervisor: 2023.12.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[20:15:24] INFO: Starting universal-silabs-flasher with /dev/ttyUSB1 (bootloader baudrate 115200)
2024-01-06 20:15:26 core-silabs-flasher universal_silabs_flasher.flash[151] INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=1, sdk_version='4.3.2', ezsp_version='7.3.2.0', ot_rcp_version=None, fw_type=<FirmwareImageType.NCP_UART_HW: 'ncp-uart-hw'>, baudrate=115200)
2024-01-06 20:15:26 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-01-06 20:15:28 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.EZSP at 115200 baud
2024-01-06 20:15:29 core-silabs-flasher bellows.ezsp[151] WARNING Protocol version 13 is not supported, using version 12 instead
2024-01-06 20:15:29 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Detected ApplicationType.EZSP, version '7.4.0.0 build 0' (7.4.0.0.0) at 115200 baudrate (bootloader baudrate None)
2024-01-06 20:15:30 core-silabs-flasher bellows.ezsp[151] WARNING Protocol version 13 is not supported, using version 12 instead
2024-01-06 20:15:30 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-01-06 20:15:30 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Detected bootloader version '2.1.1'
2024-01-06 20:15:30 core-silabs-flasher universal_silabs_flasher.flasher[151] INFO Detected ApplicationType.GECKO_BOOTLOADER, version '2.1.1' at 115200 baudrate (bootloader baudrate 115200)
firmware.gbl
[20:16:08] INFO: universal-silabs-flasher-up script exited with code 0
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service universal-silabs-flasher: stopping
s6-rc: info: service universal-silabs-flasher successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stoppedtype or paste code here
