Help with a fan and its speeds
I have a Maxcio 400ML diffuser I would like to migrate from Tasmota to ESPHome.
As it is for the Tasmota template, I would like to use it as a fan.
dpID1 is for power and dpID103 for mist strength.
But the Maxcio diffuser has a strange conception.
When plugged in,:
  • dpID1=0
  • dpID103=0
Then dpID103=0 when switched on and mist strength is low, dpID103=1 when high.
But when switched off:
  • dpID1=0
  • dpID103=2
So if I use it in a tuya template, I have 3 speeds where the third is in fact off.
And for Google Assistant in HA, even when switched off it is returned as on because speed is not 0.
Is there a solution to use it as a ESPHome fan?
I thought about using a template output but I don’t succeed in understanding how I could do that with my device.
My goal is to avoid having too much switches and sensors in HA as it is the case with Tasmota, I wish to have only the fan and the water alert sensor.
I hop I have explained enough clearly the situation.
If it could help, here is the code.
I commented all tuya fan related code, which worked excepting for this max speed when switched off.
substitutions:
  piece: Bureau
  sufix: bureau
esphome:
  platform: ESP8266
  board: esp01_1m
  project:
    version: "1.0.0"
#web_server:
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_key
  ap:
    password: !secret ap_key
captive_portal:
api:
  password: !secret api_pass
ota:
  password: !secret ota_pass
uart:
  baud_rate: 9600
  tx_pin: GPIO1
  rx_pin: GPIO3
# debug:
logger:
  baud_rate: 0
  level: NONE
tuya:
binary_sensor:
  - platform: "tuya"
    name: Eau Diffuseur ${piece}
    sensor_datapoint: 12
    device_class: "problem"
  - platform: tuya
    sensor_datapoint: 1
    internal: true
fan:
  #- platform: tuya
    #name: "Diffuseur ${piece}"
    #id: diffuseur_${sufix}
    #switch_datapoint: 1
    #speed_datapoint: 103
    #speed_count: 3
  - platform: speed
    output: fan_output
    speed_count: 2
output:
    type: float
    write_action:
      then:
          - lambda: -|
            if (state == 50) id(turbo).publish(false);
            else if (state == 100) id(turbo).publish(true);
        else:
          switch.turn_off: power
  - platform: tuya
    sensor_datapoint: 103
    internal: true
    #on_value_range:
      #above: 2
      #then:
        #- fan.turn_off: diffuseur_${sufix}
light:
  - platform: tuya
    name: Leds Diffuseur ${piece}
    dimmer_datapoint: 111
    switch_datapoint: 11
    min_value: 1
