I have installed HA Core/Supervisor ver 0.106.5 (hassio) in a NUC/Ubuntu 18.04
The last few hours I don’t see the addons I have installed. (like mosquitto,configurator etc)
They are working but there aren’t available in the supervisor menu (see photo below)
my log files are
020-03-30 00:49:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-03-30 00:49:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for meross_cloud which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-03-30 00:49:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-03-30 00:49:23 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-03-30 00:49:23 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for floureon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
however in system - logs I have the following
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[22:08:45] INFO: Update udev informations
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
20-03-29 22:08:47 INFO (MainThread) [__main__] Initialize Supervisor setup
20-03-29 22:08:47 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 213
20-03-29 22:08:47 INFO (MainThread) [__main__] Setup Supervisor
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-03-29 22:08:47 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.services] Update service information
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-03-29 22:08:47 INFO (MainThread) [supervisor.host.services] Reload local service hassio-apparmor.service
20-03-29 22:08:47 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-03-29 22:08:47 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 3
20-03-29 22:08:47 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-cli with version 23
20-03-29 22:08:47 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to homeassistant/amd64-hassio-audio with version 9
20-03-29 22:08:47 INFO (MainThread) [supervisor.dns] Start CoreDNS plugin
20-03-29 22:08:47 INFO (MainThread) [supervisor.cli] Start cli plugin
20-03-29 22:08:47 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-03-29 22:08:47 INFO (SyncWorker_5) [supervisor.docker.interface] Clean hassio_dns application
20-03-29 22:08:47 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_cli application
20-03-29 22:08:47 INFO (MainThread) [supervisor.audio] Start Audio plugin
20-03-29 22:08:47 INFO (SyncWorker_1) [supervisor.docker.interface] Clean hassio_audio application
20-03-29 22:08:49 INFO (SyncWorker_1) [supervisor.docker.audio] Start Audio homeassistant/amd64-hassio-audio with version 9 - 172.30.32.4
20-03-29 22:08:49 INFO (SyncWorker_5) [supervisor.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 3 - 172.30.32.3
20-03-29 22:08:49 INFO (MainThread) [supervisor.dns] Updated /etc/resolv.conf
20-03-29 22:08:49 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/amd64-hassio-cli with version 23 - 172.30.32.4
20-03-29 22:08:49 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.106.5
20-03-29 22:08:49 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-03-29 22:08:49 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-03-29 22:08:49 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 65 new - 0 remove
20-03-29 22:08:49 INFO (MainThread) [supervisor.addons] Found 5 installed add-ons
20-03-29 22:08:49 INFO (SyncWorker_15) [supervisor.docker.interface] Attach to hassioaddons/sqlite-web-amd64 with version 2.2.0
20-03-29 22:08:49 INFO (SyncWorker_18) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.1
20-03-29 22:08:49 INFO (SyncWorker_16) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 4.7
20-03-29 22:08:49 INFO (SyncWorker_19) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-ssh with version 8.5.2
20-03-29 22:08:49 INFO (SyncWorker_17) [supervisor.docker.interface] Attach to homeassistant/amd64-addon-deconz with version 5.3.1
20-03-29 22:08:49 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-29 22:08:49 INFO (MainThread) [supervisor.snapshots] Found 2 snapshot files
20-03-29 22:08:49 INFO (MainThread) [supervisor.discovery] Load 2 messages
20-03-29 22:08:49 INFO (MainThread) [supervisor.ingress] Load 11 ingress session
20-03-29 22:08:49 INFO (MainThread) [supervisor.secrets] Load Home Assistant secrets: 6
20-03-29 22:08:49 INFO (MainThread) [__main__] Run Supervisor
20-03-29 22:08:49 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-03-29 22:08:49 INFO (MainThread) [supervisor.addons] Phase 'initialize' start 0 add-ons
20-03-29 22:08:49 INFO (MainThread) [supervisor.addons] Phase 'system' start 2 add-ons
20-03-29 22:08:49 INFO (SyncWorker_19) [supervisor.docker.interface] Clean addon_core_mosquitto application
20-03-29 22:08:49 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_core_deconz application
20-03-29 22:08:50 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-deconz with version 5.3.1
20-03-29 22:08:50 INFO (SyncWorker_19) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-mosquitto with version 5.1
20-03-29 22:08:52 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
20-03-29 22:08:55 INFO (MainThread) [supervisor.addons] Phase 'services' start 2 add-ons
20-03-29 22:08:55 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_a0d7b954_sqlite-web application
20-03-29 22:08:55 INFO (SyncWorker_14) [supervisor.docker.interface] Clean addon_core_ssh application
20-03-29 22:08:56 INFO (SyncWorker_14) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 8.5.2
20-03-29 22:08:56 INFO (SyncWorker_4) [supervisor.docker.addon] Start Docker add-on hassioaddons/sqlite-web-amd64 with version 2.2.0
20-03-29 22:08:57 INFO (MainThread) [supervisor.auth] Auth request from core_mosquitto for MakisMosquito
20-03-29 22:08:57 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-03-29 22:08:57 INFO (MainThread) [supervisor.auth] Home Assistant not running, check cache
20-03-29 22:08:57 INFO (MainThread) [supervisor.auth] Cache hit for MakisMosquito
20-03-29 22:08:57 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_sqlite-web
20-03-29 22:08:58 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_sqlite-web
20-03-29 22:09:01 INFO (SyncWorker_1) [supervisor.docker.interface] Start homeassistant/qemux86-64-homeassistant
20-03-29 22:09:12 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-03-29 22:09:27 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-03-29 22:09:32 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-03-29 22:10:07 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-03-29 22:10:17 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-29 22:10:17 INFO (MainThread) [supervisor.addons] Phase 'application' start 1 add-ons
20-03-29 22:10:17 INFO (SyncWorker_17) [supervisor.docker.interface] Clean addon_core_configurator application
20-03-29 22:10:18 INFO (SyncWorker_17) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 4.7
20-03-29 22:10:23 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-29 22:10:23 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardware monitor
20-03-29 22:10:23 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-29 22:10:23 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-29 22:10:23 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-29 22:10:23 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-29 22:10:23 INFO (MainThread) [supervisor.host.services] Update service information
20-03-29 22:10:23 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-29 22:10:23 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-03-29 22:10:23 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-29 22:10:23 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Home Assistant is working fine except all the above
What should I do?
** To any moderator. If the above messaged are critical and no supposed to be posted please tell me or hide them.
