Help With Alexa Intents
Hello
I just got done Upgrading from HA 0.49.1 to 0.86.3 I finally got everything working.
Haaska done and working except my Intents in HA.
I had a alexa.yaml file but now it has to be
alexa:
smarthome:
I’m not sure how to format it under the smarthome structure, I have been using my alexa.yaml file looked like this
intents:
  ActivateSceneIntent:
      service: scene.turn_on
      data_template:
        entity_id: scene.{{ Scene | replace(" ", "_") }}
    speech:
      type: plaintext
      text: OK
  WhereIsCarIntent:
    speech:
      type: plaintext
      text: >
        {%- if is_state('device_tracker.dee', 'home') -%}
          Dee is at home
        {%- else -%}
          The car is at {{ states("device_tracker.dee") }}
        {% endif %}
  RoomTemperature:
    speech:
      type: plaintext
      text: >
        {%- set temp = states('sensor.dark_sky_temperature') | round -%}
        {%- set bed = states('sensor.bedroom_temperature') | round -%}
        {%- set bed_h = states('sensor.bedroom_humidity') | round -%}
        {%- set t_hi = states('sensor.dark_sky_daily_high_temperature') | round -%}
        {%- set t_low = states('sensor.dark_sky_daily_low_temperature') | round -%}
        {%- set feel = states('sensor.dark_sky_apparent_temperature') | round -%}
        {%- set humid = states('sensor.dark_sky_humidity') | round -%}
        {%- set now = states('sensor.dark_sky_summary') -%}
        {%- set hourly = states('sensor.dark_sky_hourly_summary') -%}
        {%- set daily = states('sensor.dark_sky_daily_summary') -%}
        {%- set wind = states('sensor.dark_sky_wind_speed') -%}
        Right now, it is {{ temp }} degrees Out side
        {%- if temp != feel -%}
        but it feels like {{ feel }} degrees
        {%- endif -%}.
        The current humidity is {{ humid }}%.
        Right now, conditions are {{ now }}.
        For today, {{ hourly }}.
        Today's high is {{ t_hi }} and the low is {{ t_low }}.
        The wind speed is {{ wind }} miles per hour.
        The forecast calls for {{ daily }}.
  LivingTemp:
    speech:
      type: plaintext
      text: >
        {%- set lvrm = states('sensor.livingroom_temp') | round -%}
        {%- set lvrm_h = states('sensor.livingroom_humidity') | round -%}
        Right now, it is {{ lvrm }} degrees in the living room.
        And the humidity is {{ lvrm_h }}%
Everything works I can turn on and off lights, open/close my blinds, I also was using
alexa: !include alexa.yaml
and would like to keep using the, !include if I can
Thank you
Anyone have a thought?
