Hi, I’m new to AH and trying to make an automation to match my givenergy battery SOCs (GivTCP changes one only based on solar prediction and I want to change the second to match). I have tried this but keep getting a message in traces saying
Error: Value 0.0 for number.lhs_inverter_ce2230g309_target_soc is outside valid range 4.0 - 100.0
Heres what I have tried:
alias: TBC
description: “”
triggers:
entity_id:
number.rhs_inverter_ce2223g194_target_soc
trigger: state
conditions:
condition: time
after: “23:10:00”
before: “23:58:00”
weekday:
This is not a valid entity id. It is missing the ‘number.’ prefix. You should always try templates in developer tools to see if they work before putting them in an automtion or sensor.
Please when you post yaml, properly format by using the </> code format block. The forum distroys relevant information to see possible errors and makes it almost impossible to read the automation properly.
