Help with Anycubic Integration
Team,
sorry to bother but I’m not able to run correctly the integration.
I think is because I cannot mount Python, pip and the required libraries, but I’m lost on how to do it.
adamoutler/anycubic-homeassistant: Home assistant integration for Anycubic Printers. (github.com)
I’ve installed the SSH integration so when I log in I should be in the docker already:
| |  | |                          /\           (_)   | |            | |
| |__| | ___  _ __ ___   ___     /  \   ___ ___ _ ___| |_ __ _ _ __ | |_
|  __  |/ _ \| '_ \ _ \ / _ \   / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| |  | | (_) | | | | | |  __/  / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_|  |_|\___/|_| |_| |_|\___| /_/    \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for enp0s3: xx
  IPv6 addresses for enp0s3: xx
  OS Version:               Home Assistant OS 11.2
  Home Assistant Core:      2023.12.4
  Home Assistant URL:       xx
  Observer URL:             xx
[core-ssh ~]$ docker exec -it homeassistant /bin/bash
-bash: docker: command not found
can anyone be so kind to help me?
M
I’ve been working on an Anycubic cloud integration if you want to test it out instead :slight_smile:
Just grabs information via the cloud API so you will need an anycubic account:
hass-anycubic_cloud
modded threedy plugin (frontend card)
