Help with automation with wait_template
Hello guys!
I cannot figure out what is going on here… This is an automation for turning lights on and off depending on a motion sensor, actions and time:
  - alias: Luzes da casa - Quarto
      platform: state
      entity_id: binary_sensor.movimento_quarto
      to: 'on'
    condition:
      condition: state
      entity_id: light.luzes_principais_quarto
      state: 'off'
      - service: light.turn_on
      - delay: 00:00:02
      - wait_template: "{{ (is_state('light.luzes_principais_quarto' , 'off')) or (((now() - states.binary_sensor.movimento_quarto.last_updated).seconds /60) | int >= states.input_number.timmer_quarto.state |int and is_state('binary_sensor.movimento_quarto' , 'off')) }}"
      - condition: state
        state: 'on'
      - service: light.turn_off
I idea is if lights are turned off manually, just finish automation until next trigger or wait for an input_number number of minutes and for the sensor to be off to turn lights off.
The automation triggers, lights turns on but nothing else happens. I get true when tested with template testing on dev tools, very odd.
Is it possible to have multiple wait conditions on the same line?
Thanks a lot!
the cause is most likely the now() in your template. Templates do not update if your time changes when using now(). Templates only update when entities inside the equation update. So if nothing in the equation is updating… then it will never continue. If you use the datetime sensor instead of now(), it may rectify the problem.
here’s the datetime sensor:
Amazing stuff sir! Thanks a lot! I will try it tomorrow morning an let you know the result. Cheers!
Hello @petro! So sorry to bother you again my friend…
I’ve managed to set up the Time and Date component successfully but could not figure how to calculate the minutes between those two times.
Could you please help me out again? :slight_smile:
With the last updated state from the sensor I get this:
{{ states.binary_sensor.movimento_quarto.last_updated }} = 2018-08-06 16:13:36.411953+00:00
{{ states.binary_sensor.movimento_quarto.last_updated.strftime("%H:%M") }} = 16:13
{{ states.sensor.time_utc.state }} = 16:38
Could not make a calculation between them to get just the minutes…
Thanks a lot!
Ah ok. Well, you probably have to convert everything to seconds, then convert the seconds to minutes. Also, you need to use date_time, not utc. the utc sensor doesn’t give the date, and that means your automations may not work during the hours in which utc’s date and local’s date don’t match. The good news is that as_timestamp will convert it to utc for you.
{{ as_timestamp(states.binary_sensor.movimento_quarto.last_updated) }}
{{  as_timestamp(strptime(states.sensor.date_time.state, '%Y-%m-%d, %H:%M')) }}
so, subtracting and turning into minutes…
{{ (as_timestamp(strptime(states.sensor.date_time.state, '%Y-%m-%d, %H:%M')) - as_timestamp(states.binary_sensor.movimento_quarto.last_updated) ) / 60 }}
Amazing job @petro , again, my friend!
You are like the sentinel of tricky automation here on the forum hahaha
It worked like a charm! Here is the final wait_template:
- wait_template: "{{ ((is_state('light.luzes_principais_quarto' , 'off')) or ( (((as_timestamp(strptime(states.sensor.date__time.state, '%Y-%m-%d, %H:%M')) - as_timestamp(states.binary_sensor.movimento_quarto.last_updated) ) / 60) | int) >= states.input_number.timmer_quarto.state | int and is_state('binary_sensor.movimento_quarto' , 'off'))) }}"
Will try it tonight to see if lights goes off automatically with this automation.
Thanks a lot mate! Cheers!
Hopefully it works! I’ve seen wait templates act weird before.
Hello again!
Just tested the automation at home and can say that it works perfectly!
Here it is:
      platform: state
      to: 'on'
    condition:
      condition: state
      state: 'off'
      - delay: 00:00:05
      - wait_template: "{{ ((is_state('light.luzes_principais_quarto' , 'off')) or ((((as_timestamp(strptime(states.sensor.date__time.state, '%Y-%m-%d, %H:%M')) - as_timestamp(states.binary_sensor.movimento_quarto.last_updated) ) / 60) | int) >= states.input_number.timmer_quarto.state | int and is_state('binary_sensor.movimento_quarto' , 'off'))) }}"
      - condition: state
        state: 'on'
Oddly, I had to put a delay: 00:00:05 just before the wait_template, if not, the automation hags just like before.
I’ve created a few input_number sliders so I can set the minutes I want the lights to go off:
Now I just need to discover how to set these sliders to be only these number available “1,2,3,4,5,10,20,30”, so it could be a bit smaller a easier to set.
Thanks a lot again mate! Have a great one!
not sure that is possible. Have you thought about input_datetimes?
Much easier to input a time.
Never knew about this componente, very neat! This is very useful for creating an alarm clock system inside HA. I’ve never found a simple solution to do it. Very nice! Will take a look. Thanks!
Hi Schneider,
I’m interested how do you create that timers’ list and how do you insert the timer into an automation.
I’m not strong with code so, please, could you explain me step by step?
My goal is to have a timer slide to set a delay in a automation’s action
Thank you in advance.
You can use a input_number as slider. And use it in the autoamtion as delay like it is descriped here https://www.home-assistant.io/docs/scripts/#delay
thank you for the answer
If I try to put this in the lovelace.yaml, the slider is not visible:
type:
input_number:
  minutes:
    initial: 10
    min: 2
    max: 20
    step: 1
    unit_of_measurement: minutes
The preferred way to configure an input number is via the user interface at ConfigurationHelpers . Click the add button and then choose the Number option.
More Information to input_numbers: Input Number - Home Assistant
After adding the input_number add this to your lovelace.ymal:
type: entities
entities:
  - input_number.slidertest
But replace input_number.slidertest with the name you gave your input number.
More Information to the lovelace card are here. Entities Card - Home Assistant
In the automation the delay can be done by adding this.
delay: '{{states("input_number.slidertest")}}'
Hope it works
FYI
It’s necessary to add hours and minuts on the string like this:
- delay: '00:{{states("input_number.movimento_marco") | int }}:00'
Thank you, thank you so much.
