Help with climate automation Tesla
Hi
I’m not able to get my climate automation to work on my Tesla. I get the automation part to trigger correctly, but it does not enable the climate module correctly. Also the built in Tesla component and climate part works fine isolated from my automation efforts.
The automation :
- alias: Bilvarme timer man-tor
    - platform: time
      at: '7:50'
  condition:
    - condition: time
      weekday:
        - mon
        - tue
        - wed
        - thu
    - service: climate.set_operation_mode
        entity_id: climate.tesla_model_s_5yjsa7e26gf120793_hvac_climate_system
        operation_mode: on
The climate entity :
state:
off
Attributes:
operation_list: on,off
operation_mode: off
The problem is that setting the operation_mode to ‘on’, does not make the climate entity to enable the heating / ventilation on the Tesla API. Also verified with tcpdump that enabling the operation_mode does not trigger any communication with the Tesla API.
Will also look into enhancing this with adjusting pre-heat time based on outside temperature, but will need the basics to work first :slight_smile:
best regards
This is working for me:
 - alias: 'Varme Tesla Hjemme'
     platform: template
     value_template: '{{ states.sensor.time.state == states.sensor.teslatime.state }}'
   condition:
     condition: and
     conditions:
       - condition: numeric_state
         entity_id: sensor.tesla_model_s_5yjsa7e28hf212926_battery_sensor
         above: 30
         entity_id: sensor.tesla_model_s_5yjsa7e28hf212926_temperature_sensor_outside
         below: 7
       - condition: state
         entity_id: device_tracker.tesla_model_s_5yjsa7e28hf212926_location_tracker
         state: 'home'
       - condition: time
         weekday:
           - mon
           - tue
           - wed
           - thu
           - fri
         entity_id: climate.tesla_model_s_5yjsa7e28hf212926_hvac_climate_system
         operation_mode: 'on'
     - service: notify.html5
         message: "Teslavarme på"
I’m also having issues with Tesla hvac automation. In my case, the automation successfully turns on the hvac but only if I have recently used the Tesla app to “waken” the car.
Yep, did you guys figure out a solution?
Using the app to wake up the car first before automation can work is not really “automating” anything…
There is an open issue about this on github. Seems like the problem lies with the teslajsonpy library. Someone has offered to fix it, but the guy who owns that library doesn’t seem to respond…
This needs to be looked at.
What happens on github when the maintainer is MIA?
I don’t know…
But it seems to me like there are other python tesla libs on github that are more extensive and better maintained… Others also mention that this library doesn’t work at all after tesla software v 9
Is there a workaround for this, until we get a proper fix?
I have TMS with v9 and this script works for me.
- id: tesla_hvac_morning
alias: Tesla HVAC Morning Automation
- at: 06:45:00
platform: time
condition:
- condition: state
entity_id: device_tracker.tesla_model_s_location_tracker
state: home
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
operation_mode: ‘on’
- data:
message: Tesla HVAC turned On
title: Tesla AC
service: notify.pushbullet
NB: I have replaced the identificator with … Not sure if that should be posted public or not.
I came here looking for answer to this question for my new Model 3. I think I have figured out why it would work from the web interface but fail when I tried to have a automation call it.
You can’t call the service “climate.turn_on”
You must call “climate.set_operation_mode” and set “operation_mode”: “ON”
Ok, I may have found a workaround for this. My car did wake up this morning when I sent it a command.
Tested it this morning with success… I’ll do some more tests during the day.
Ok, I have successfully managed to turn on the climate when the car is hibernating.
First command sent to the car, did nothing → wait 10-15 seconds → second command turns on the climate.
Looks like the car wakes up the first time but do not accept/recieve command to turn on the climate. Second time works as normal.
Seems like there isn’t any set_operation_mode anymore.
Setting the
hvac_mode: heat_cool
does seem to defrost the car:
service: climate.set_hvac_mode
  entity_id: climate.mytesla_hvac_climate_system
However setting
hvac_mode: auto
doesn’t seem to do anything.
Any hints how to climatize to a target temperature of 22 degrees celsius?
Did you find the setting for 22 degrees ?
I can use:
“off” for off
“heat_cool” for defrost
But is missing the normal heating, without defrost :slight_smile:
No. I also haven’t found a real solution so far.
This scene works for me:
- name: I'm Getting Ready to Leave
  icon: "mdi:car"
  entities:
    climate.tesla_model_y_hvac_climate_system:
      state: heat_cool
You should be able to call it from your automation or just tell Siri/Google/Alexa, “I’m getting ready to leave” :smile:
I wat to add a button to defrost the car. Specifically defrost, not to run heater, like a button in the app.
How can I do it?
Your service call seems to only enable climate control, but not defrost?
I know this thread is old at this point, but adding this for anyone still wondering; just using the climate “on” has been working for me.
service: climate.turn_on
data: {}
  entity_id: climate.sparky_hvac_climate_system
For anyone interested, I tried to gather the relevant info I found in an article Dynamically preheating the car with Home Assistant
