Help with CLIMATE
Hi
I use TADO and managed to get the deprecated homebridge addon installed so I am controlling it using homebridge locally.
I am able to turn on rooms or the hot water with climate.set_temperature to specify a temperature and HVAC mode (heat), but this does it permananetly - I just want to be able to press a button that heats my room (climate.masterbedroom) for 20 mins only at 25C - but this doesnt seem possible.
Is the work-around to make an automation ‘when climate.masterbedroom’ set to HVAC -heat for 20 mins - then climate.set_temperateure to 10C and HVAC - off (or do I select auto here?)
