Help with condition template using sensor attribute
Hi fellow automators :smiley:
Entity Page:
Entity:
  binary_sensor.motion_sensor_158d0001e52dee
State:
  on
Attributes:
  No motion since: 1800
  battery_level: 41
  friendly_name: Motion Hallway
  device_class: motion
Automation.yaml
- alias: 'no motion test'
  condtion:
    - condition: template
      value_template: "{{ states.binary_sensor.motion_sensor_158d0001e52dee.attributes['No motion since'] > 300 }}"
     - service: persistent_notification.create
         message: "No motion for > 300 has returned true"
         title: "Test"
The syntax for the value template condition is incorrect, and I can’t figure out why.
I want to return a condition = true if ‘no motion since’ > ‘300’.
Thanks for any help
What does the Templates Tool show if you paste
{{ states.binary_sensor.motion_sensor_158d0001e52dee.attributes['No motion since'] }} in?
Maybe convert to int?
{{ states.binary_sensor.motion_sensor_158d0001e52dee.attributes['No motion since'] | int > 300 }}
i have never used the template tool, but that definitely sounds like something i should use. I will try and report back! thank you.
in the template tool. comes back with
300
so that part works!
gives me
True
Yeah, I’ve been working on this one line for almost 1 hour :frowning:
try adding an “int” filter to the attribute read:
value_template: "{{ states.binary_sensor.motion_sensor_158d0001e52dee.attributes['No motion since'] | int > 300 }}"
In the example you gave, there is a spelling mistake, condtion:
