Help with configuration of Telldus + Danfoss and Home assistant
Hi all, first post here.
I’ve bought a raspberry pi 3, telldus znet lite v2 and a danfoss living comfort (lc13) and a temp. giver.
I got the telldus part up and running and also the home assistant. I’m very new to this though and the tutorials I’m following don’t really help me out much.
What I want to do is basicly, keep the house at a steady 22. I don’t really understand how the Danfoss LC13 works, but it’s supposed to be “smart”. I have so many questions but I’ll try to be as specific as possible and hopefully someone can help me out :slight_smile:
  1. How does the LC13 really work? Depending on how hard it “pushes the little stick” that decides the waterflow, how will it know how hard/little it needs to push? Do I have to create an event? I can only choose on/off in the event.
  2. Can I control this with home assistant or is it only live.telldus.com?
  3. Is it possible to do what I have described? i.e telldus checks the temperature, then tells danfoss how much it should push the stick
Home assistant has connected with my local api for telldus and I can see the sensor and device on the overview page, but that’s about it. Can’t do much with it.
