hey i am new to home assistant and recently bought some wifi feconn rgb bulbs and am wondering if its possible to use the home assistant to onnect them to a phillips hue dimmer switch in any way?
Yes, you can mix and match wifi devices to control zigbee devices. You would need to have wifi devices supported by HA through integrations and connect your zigbee devices through Z2M / ZHA / Deconz.
thanks a lot do you have any advice or tips on how to do it?
To get Zigbee support you need a coordinator and to install ZHA/Z2M/Deconz. Or if you have a Hue hub you can use that, but that limits you a bit on what kind of devices you can connect.
I personally am very happy with www.zigbee2mqtt.io, look at their documentation to get started. Iām not familiar with your brand of wifi bulbs so you need to find that out yourself.
yep i know i am able to connect the lights and the dimmer switch i just am unsure of how to get them to interact with eachother?
With automations.
