I am very new to docker and to making my own addon.
I am trying to build an add on that runs a python script.
My folder structure looks like this:
- scripts
- main.py
- logger.py
- etc.
- config.yaml
- Dockerfile
- run.sh
- test.log
I am trying to copy the scripts folder but it does not work.
This is my DOckerfile:
ARG BUILD_FROM
FROM $BUILD_FROM
# Install requirements for add-on
RUN \
apk add --no-cache \
python3
# Python 3 HTTP Server serves the current working dir
# So let's set it to our add-on persistent data directory.
WORKDIR /data
# Copy data for add-on
COPY run.sh /
COPY scripts /data/scripts
RUN chmod a+x /run.sh
CMD [ "/run.sh" ]
This is my run.sh
#!/usr/bin/with-contenv bashio
echo "Checking prerequisites"
python3 -m venv /data/venv
source /data/venv/bin/activate
python3 -m ensurepip --upgrade >/dev/null
pip install --upgrade google-api-python-client google-auth-httplib2 google-auth-oauthlib lxml requests num2words >/dev/null
echo "Starting Scripts..."
DEBUG=$(bashio::config 'debug')
python3 scripts/main.py $(bashio::config 'debug')
echo Scripts finished
python3 -m http.server 9090
The result I get if I run this is : python3: can't open file '/data/scripts/main.py': [Errno 2] No such file or directory
If try to see the contents of the data dir I only see options.json and a venv folder.
Why are my files not copied?
