Help with data_template inside of a script
Hoping someone can lend me a hand here.
Im still coming to grips with templating.
Im trying to turn on a light or a switch(fan) depending on the state of a couple input_selects.
If I enable the automation & script in my config files, HASS dumps out a huge error when I run Check Config.
Here is the Automation
alias: Motion Kitchen Lights
  platform: state
  entity_id: binary_sensor.centralite_3326l_05989fde_1
  to: 'on'
  service: script.motion_kit.yaml
Here is the Script
sequence:
- service: fan.turn_on
  data_template:
    entity_id: >
      {% if is_state("input_select.house_override", "Sleep") %}
        fan.ge_12730_fan_control_switch_levelh
      {% if is_state("input_select.livingroom_override", "Movie") %}
      {% else %}
        none
      {% endif %}
- service: switch.turn_on
  data_template:
    entity_id: >
        none
        none
      {% else %}
        switch.ge_12722_onoff_relay_switch_switch
      {% endif %}
1 - doesnā€™t affect whether or not your config validates, but thereā€™s no reason to run a script as the only action of an automation, just put the contents of the script as the action.
2 - we canā€™t help you fix the format of your code without being able to see your formatting. Please use a code block.
Hello again @anon43302295
Thats odd I thought for sure I clicked the option to add it s a code block the first time.
Its been edited, should show correctly now.
Only reason I ran it as a script was I was not aware you can have an automation run two different types of entities. In this case a fan.XXX and a switch.xxx. I figured this would be one of the use cases for scripts.
If I can run it directly in the automation itself, Im open to it.
Whatā€™s the error?
Not sure what just happened.
This should be all you needā€¦
  platform: state
  to: 'on'
  service: homeassistant.turn_on
  data_template:
    entity_id: >
      {% elif is_state("input_select.livingroom_override", "Movie") %}
      {% else %}
      {% endif %}
Should that H be on the end of the first fan btw?
Just tried it, and I still get a huge error.
Testing configuration at /config
2018-02-25 02:58:57 INFO (MainThread) [homeassistant.setup] Setting up introduction
2018-02-25 02:58:57 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-02-25 02:58:57 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.8 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up http
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up system_log
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up api
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up history
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up frontend
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up map
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up sensor
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up zwave
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up input_select
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up wink
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up nest
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up sun
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up scene
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up zha
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up updater
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up joaoapps_join
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up group
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up notify
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up zone
2018-02-25 02:58:58 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: invalid template (TemplateSyntaxError: Unexpected end of template. Jinja was looking for the following tags: 'elif' or 'else' or 'endif'. The innermost block that needs to be closed is 'if'.) for dictionary value @ data['action'][0]['data_template']['entity_id']. Got None. (See /config/configuration.yaml, line 92). Please check the docs at https://home-assistant.io/components/automation/
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.8 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.8 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.5 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.5 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.5 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.4 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain wink took 0.4 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain nest took 0.4 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.4 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.3 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain zha took 0.3 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.3 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.3 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain joaoapps_join took 0.2 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.2 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.2 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.2 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up conversation
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up panel_iframe
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up camera
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up config
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up google_assistant
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up mqtt_statestream
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain panel_iframe took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up script
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up light
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up remote
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up switch
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain google_assistant took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt_statestream took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain remote took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2018-02-25 02:58:58 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds.
Failed config
  automation:
    - action: [source /config/automation/sunrise_outdoor_lights.yaml:6]
        service: script.outdoor_off
      alias: Sunrise, outdoor lights
      trigger: [source /config/automation/sunrise_outdoor_lights.yaml:2]
        platform: sun
        event: sunrise
        offset: +00:30:00
    - action: [source /config/automation/sunset_outdoor_lights.yaml:6]
        service: script.outdoor_on
      alias: Sunset, outdoor lights
      trigger: [source /config/automation/sunset_outdoor_lights.yaml:2]
        platform: sun
        event: sunset
        offset: -00:30:00
    - action: [source /config/automation/motion_lr.yaml:6]
        entity_id: group.all_living_room_lights
        service: group.turn_on
      alias: Motion Livingroom Lights
      trigger: [source /config/automation/motion_lr.yaml:2]
        platform: state
        entity_id: binary_sensor.centralite_3326l_0e29bfd8_1
        to: on
    - action: [source /config/automation/motion_dr.yaml:6]
        entity_id: light.ge_12724_3way_dimmer_switch_level
        service: light.turn_on
      alias: Motion Dining Room Lights
      trigger: [source /config/automation/motion_dr.yaml:2]
        platform: state
        entity_id: binary_sensor.centralite_3326l_0598986c_1
        to: on
    - action: [source /config/automation/motion_office.yaml:6]
        entity_id: light.osram_lightify_a19_rgbw_00a68da9_3
      alias: Motion Office Lights
      trigger: [source /config/automation/motion_office.yaml:2]
        platform: state
        entity_id: binary_sensor.centralite_3326l_059899ee_1
        to: on
    - action: [source /config/automation/motion_kit.yaml:6]
        data_template: [source /config/automation/motion_kit.yaml:8]
          entity_id: {% if is_state("input_select.house_override", "Sleep") %}
{% else %}
{% endif %}
      trigger: [source /config/automation/motion_kit.yaml:2]
        platform: state
        to: on
    - action: [source /config/automation/motion_din.yaml:6]
      trigger: [source /config/automation/motion_din.yaml:2]
        platform: state
        to: on
    - action: [source /config/automation/motion_hall.yaml:6]
        entity_id: group.hallway_lights
      alias: Motion Hallway Lights
      trigger: [source /config/automation/motion_hall.yaml:2]
        platform: state
        to: on
    - action: [source /config/automation/timer_lr.yaml:6]
      trigger: [source /config/automation/timer_lr.yaml:2]
        platform: sun
        event: sunset
        offset: -00:30:00
Successful config (partial)
  automation:
    - action: ?
        - service: script.outdoor_off
      hide_entity: False
      trigger: ?
        - platform: sun
          event: sunrise
          offset: 0:30:00
    - action: ?
        - service: script.outdoor_on
      hide_entity: False
      trigger: ?
        - platform: sun
          event: sunset
          offset: -1 day, 23:30:00
    - action: ?
        - entity_id: ?
            - group.all_living_room_lights
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
            - binary_sensor.centralite_3326l_0e29bfd8_1
          to: on
    - action: ?
        - entity_id: ?
            - light.ge_12724_3way_dimmer_switch_level
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
            - binary_sensor.centralite_3326l_0598986c_1
          to: on
    - action: ?
        - entity_id: ?
            - light.osram_lightify_a19_rgbw_00a68da9_3
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
            - binary_sensor.centralite_3326l_059899ee_1
          to: on
    - action: ?
        - entity_id: ?
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
          to: on
    - action: ?
        - entity_id: ?
            - group.hallway_lights
      hide_entity: False
      trigger: ?
        - platform: state
          entity_id: ?
          to: on
    - action: ?
      hide_entity: False
      trigger: ?
        - platform: sun
          event: sunset
Sorry, fixed in my post above (including removing what I think is an erroneous H )
That did it! Thank you.
Good catch on that random ā€œHā€
So two questions.
ā€œelifā€ means or right?
Also is homeassistant.turn_on just a generic service that can turn on any entity I throw at it?
Elif is short for else if,
So first it checks the IF, and if that evaluates true you get that result, if it evaluates false it moves to the next one, so weā€™re then saying itā€™s none of the above (else), but is it this (if), which is shortened to ELIF, which you can do as many of as you like. Then at the bottom we have ELSE where we are saying nothing above is true so do this instead.
And yes, homeassistant.turn_on is basically ā€˜turn onā€™ no matter what domain. :+1:
Perfect, both are good to know.
Thanks for your help
