Help with devcontainers and docker compose
I have followed the instructions in Set up Development Environment | Home Assistant Developer Docs to see if I can debug an integration that is not working for me (tuya_ble).
When I first followed the instructions I was able to run and debug home assistant.
However, to test the integration properly, I need to somehow give the devcontainer access to my USB bluetooth dongle. To that end, I figure that I somehow need to incorporate docker compose to do that mapping of the USB device.
I have taken the core devcontainer.json from my cloned HA gitbhub repository and modified it as follows (removed the dockerfile property and replaced it with the dockerComposeFile, service and runServices properties.
	"name": "Home Assistant Dev",
	"context": "..",
	"service": "homeassistant",
	"runServices": "homeassistant",
	"dockerComposeFile": "docker-compose.yml",
	"postCreateCommand": "script/setup",
	"postStartCommand": "script/bootstrap",
	"containerEnv": { "DEVCONTAINER": "1" },
	"appPort": ["8123:8123"],
	"runArgs": ["-e", "GIT_EDITOR=code --wait"],
	"customizations": {
	  "vscode": {
		"extensions": [
		  "charliermarsh.ruff",
		  "ms-python.pylint",
		  "ms-python.vscode-pylance",
		  "visualstudioexptteam.vscodeintellicode",
		  "redhat.vscode-yaml",
		  "esbenp.prettier-vscode",
		  "GitHub.vscode-pull-request-github"
		// Please keep this file in sync with settings in home-assistant/.vscode/settings.default.json
		"settings": {
		  "python.pythonPath": "/usr/local/bin/python",
		  "python.testing.pytestArgs": ["--no-cov"],
		  "editor.formatOnPaste": false,
		  "editor.formatOnSave": true,
		  "editor.formatOnType": true,
		  "files.trimTrailingWhitespace": true,
		  "terminal.integrated.profiles.linux": {
			"zsh": {
			  "path": "/usr/bin/zsh"
		  "terminal.integrated.defaultProfile.linux": "zsh",
		  "yaml.customTags": [
			"!input scalar",
			"!secret scalar",
			"!include_dir_named scalar",
			"!include_dir_list scalar",
			"!include_dir_merge_list scalar",
			"!include_dir_merge_named scalar"
		  "[python]": {
			"editor.defaultFormatter": "charliermarsh.ruff"
Within the .devcontainer folder, I created a docker-compose.yml file as follows (note I haven’t even got as far as mapping the usb device /dev/bus/usb/001/008):
version: '3'
services:
  # Update this to the name of the service you want to work with in your docker-compose.yml file
  homeassistant:
    # Uncomment if you want to override the service's Dockerfile to one in the .devcontainer
    # folder. Note that the path of the Dockerfile and context is relative to the *primary*
    # docker-compose.yml file (the first in the devcontainer.json "dockerComposeFile"
    # array). The sample below assumes your primary file is in the root of your project.
    build:
      dockerfile: ../Dockerfile.dev
But when I try to rebuild the container in VS code it spluts out the following
[2024-01-12T16:21:58.261Z] Start: Run: docker -v
[2024-01-12T16:21:58.291Z] Stop (30 ms): Run: docker -v
[2024-01-12T16:21:58.292Z] Start: Run: docker events --format {{json .}} --filter event=start
[2024-01-12T16:21:58.296Z] PersistedPath=/tmp/devcontainercli-root, ContainerHasLabels=false
[2024-01-12T16:21:58.298Z] Start: Run: docker compose -f /workspaces/home-assistant-core/.devcontainer/docker-compose.yml --profile * config
[2024-01-12T16:21:58.389Z] Stop (91 ms): Run: docker compose -f /workspaces/home-assistant-core/.devcontainer/docker-compose.yml --profile * config
[2024-01-12T16:21:58.390Z] name: devcontainer
services:
  homeassistant:
    build:
      context: /workspaces/home-assistant-core/.devcontainer
    networks:
      default: null
networks:
  default:
[2024-01-12T16:21:58.394Z] Start: Run: docker inspect --type image mcr.microsoft.com/vscode/devcontainers/python:0-3.11
[2024-01-12T16:21:58.422Z] Stop (28 ms): Run: docker inspect --type image mcr.microsoft.com/vscode/devcontainers/python:0-3.11
[2024-01-12T16:21:59.226Z] Docker Compose override file for building image:
version: '3'
services:
  homeassistant:
    build:
      dockerfile: /tmp/devcontainercli-root/container-features/0.54.1-1705076519206/Dockerfile-with-features
      args:
        - BUILDKIT_INLINE_CACHE=1
        - _DEV_CONTAINERS_BASE_IMAGE=dev_container_auto_added_stage_label
[2024-01-12T16:21:59.230Z] Start: Run: docker compose --project-name home-assistant-core_devcontainer -f /workspaces/home-assistant-core/.devcontainer/docker-compose.yml -f /tmp/devcontainercli-root/docker-compose/docker-compose.devcontainer.build-1705076519226.yml build h o m e a s s i s t a n t
[2024-01-12T16:21:59.339Z] no such service: h
[2024-01-12T16:21:59.343Z] Stop (113 ms): Run: docker compose --project-name home-assistant-core_devcontainer -f /workspaces/home-assistant-core/.devcontainer/docker-compose.yml -f /tmp/devcontainercli-root/docker-compose/docker-compose.devcontainer.build-1705076519226.yml build h o m e a s s i s t a n t
[2024-01-12T16:21:59.345Z] Error: Command failed: docker compose --project-name home-assistant-core_devcontainer -f /workspaces/home-assistant-core/.devcontainer/docker-compose.yml -f /tmp/devcontainercli-root/docker-compose/docker-compose.devcontainer.build-1705076519226.yml build h o m e a s s i s t a n t
[2024-01-12T16:21:59.346Z]     at pw (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:427:522)
[2024-01-12T16:21:59.346Z]     at processTicksAndRejections (node:internal/process/task_queues:96:5)
[2024-01-12T16:21:59.346Z]     at async L$ (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:427:2493)
[2024-01-12T16:21:59.346Z]     at async N$ (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:409:3165)
[2024-01-12T16:21:59.346Z]     at async tAA (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:479:3833)
[2024-01-12T16:21:59.346Z]     at async CC (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:479:4775)
[2024-01-12T16:21:59.347Z]     at async NeA (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:612:11107)
[2024-01-12T16:21:59.347Z]     at async MeA (/root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js:612:10848)
[2024-01-12T16:21:59.360Z] Stop (2086 ms): Run in container: node /root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js up --container-session-data-folder /tmp/devcontainers-26341e6a-630e-45e5-83d8-2fef149e541e1705076513022 --workspace-folder /workspaces/home-assistant-core --workspace-mount-consistency cached --id-label vsch.local.repository=https://github.com/mcclumpherty/home-assistant-core --id-label vsch.local.repository.volume=home-assistant-core-0f8cd95874c1e7bc1f0aeb45bb9eae9a505cf970b22efd42f5ea2cbe61a93f3d --id-label vsch.local.repository.folder=home-assistant-core --id-label devcontainer.config_file=/workspaces/home-assistant-core/.devcontainer/devcontainer.json --log-level debug --log-format json --config /workspaces/home-assistant-core/.devcontainer/devcontainer.json --default-user-env-probe loginInteractiveShell --remove-existing-container --mount type=volume,source=home-assistant-core-0f8cd95874c1e7bc1f0aeb45bb9eae9a505cf970b22efd42f5ea2cbe61a93f3d,target=/workspaces,external=true --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default off --mount-workspace-git-root
[2024-01-12T16:21:59.360Z] Exit code 1
[2024-01-12T16:21:59.361Z] Start: Run: docker rm -f c278ac5c5c7b2946a540551c3a6e3ebc3948347a79bde7d28890d0ab52a19b81
[2024-01-12T16:21:59.378Z] Command failed: node /root/.vscode-remote-containers/dist/dev-containers-cli-0.327.0/dist/spec-node/devContainersSpecCLI.js up --container-session-data-folder /tmp/devcontainers-26341e6a-630e-45e5-83d8-2fef149e541e1705076513022 --workspace-folder /workspaces/home-assistant-core --workspace-mount-consistency cached --id-label vsch.local.repository=https://github.com/mcclumpherty/home-assistant-core --id-label vsch.local.repository.volume=home-assistant-core-0f8cd95874c1e7bc1f0aeb45bb9eae9a505cf970b22efd42f5ea2cbe61a93f3d --id-label vsch.local.repository.folder=home-assistant-core --id-label devcontainer.config_file=/workspaces/home-assistant-core/.devcontainer/devcontainer.json --log-level debug --log-format json --config /workspaces/home-assistant-core/.devcontainer/devcontainer.json --default-user-env-probe loginInteractiveShell --remove-existing-container --mount type=volume,source=home-assistant-core-0f8cd95874c1e7bc1f0aeb45bb9eae9a505cf970b22efd42f5ea2cbe61a93f3d,target=/workspaces,external=true --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default off --mount-workspace-git-root
[2024-01-12T16:21:59.378Z] Exit code 1
[2024-01-12T16:21:59.416Z] Stop (4358 ms): Run in container: /bin/sh
[2024-01-12T16:21:59.417Z] Stop (4218 ms): Run in container: /bin/sh
[2024-01-12T16:21:59.418Z] Container server terminated (code: 137, signal: null).
[2024-01-12T16:21:59.628Z] Stop (267 ms): Run: docker rm -f c278ac5c5c7b2946a540551c3a6e3ebc3948347a79bde7d28890d0ab52a19b81
[2024-01-12T16:22:16.169Z] Start: Run: docker volume ls -q
[2024-01-12T16:22:16.201Z] Stop (32 ms): Run: docker volume ls -q
[2024-01-12T16:22:16.242Z] Start: Run: docker version --format {{.Server.APIVersion}}
[2024-01-12T16:22:16.290Z] Stop (48 ms): Run: docker version --format {{.Server.APIVersion}}
[2024-01-12T16:22:16.290Z] 1.43
I’m clearly doing something wrong here. Does anyone have an example of how to do this sort of thing?
