Help with dict formatting going wrong
I have a trigger template which has been nicely keeping a log of browser_users for several months but has recently started going wrong when HA restarts. After updating HA this morning I discovered that the attribute which normally stores the database as a dict has changed to a string. Can anyone help me understand why, and either how to prevent it or spot the error and convert the string back to a dict?
The attribute normally looks like this:
database:
  rnli0020:
    user: RNLI
    prev: "2025-04-16T02:04:03"
    when: "2025-04-19T11:21:32"
    for: 292649
    vizes: 1
    status: uv  +292649
    width: "980"
    old: "prev:2025-04-16T01:03:46 for:0 vizes:1 status:vu "
  gig9850davidc:
    user: gig David C app
    prev: "2025-04-19T11:28:22"
    when: "2025-04-19T11:29:00"
    for: 53
    vizes: 2
    status: "vh "
    width: "412"
    old: prev:2025-04-19T11:27:29 for:53 vizes:1 status:hv  +53
But after HA restart, looks like this:
database: >-
  {'rnlia762': {'id': Undefined, 'user': '', 'prev': '', 'when':
  '2025-04-20T07:53:41', 'for': 0, 'vizes': 0, 'status': 'u', 'width': '',
  'old': ''}, 'rnli9atonyphone': {'id': 'RNLI9aTonyPhone', 'user': 'RNLI',
  'prev': '2025-04-19T23:18:36', 'when': '2025-04-20T08:11:32', 'for': 99,
  'vizes': 2, 'status': 'vh ', 'width': '980', 'old': 'prev:2025-04-19T23:16:57
  for:99 vizes:1 status:hv  +99'}, 'rnli961b': {'id': 'RNLI961b', 'user':
  'RNLI', 'prev': '2025-04-18T07:41:55', 'when': '2025-04-19T17:13:20', 'for':
  1458, 'vizes': 6, 'status': 'vv ', 'width': '1272', 'old':
  'prev:2025-04-17T16:56:06 for:1458 vizes:5 status:vv '}
My sensor code is:
  - trigger:
    - platform: state
      entity_id:
        - sensor.browser_users_last_state_viz
      not_to:
        - "unavailable"
        - "unknown"
        - 'none'
      - name: browser_users_db_viz
        unique_id: browser_users_db_viz
        state: "{{ trigger.to_state.state }}"
        attributes:
          database: >
            {#- set this = states.sensor.browser_users_db_viz #}
            {#- set trig =  states('sensor.browser_users_last_state_viz') #} {# uncomment / swap for use in Developer Tools #}
            {%- set trig = trigger.to_state.state %}
            {%- set id = trig.split(' /')[-2] if ' /' in trig else trig %}
            {%- set ids = 'sensor.' ~ id | slugify ~ '_browser_user' %}
            {%- set idw = 'sensor.' ~ id | slugify ~ '_browser_width' %}
            {%- set db = dict(this.attributes.get('database', {}).items() | selectattr('0', 'eq', id)) if this.attributes.database.items is defined else {} %}
            {%- set others = dict(this.attributes.get('database', {}).items() | rejectattr('0', 'eq', id)) if this.attributes.database.items is defined else {} %}
            {%- set ids, who, old, name = 'sensor.' ~ id | slugify ~ '_browser_user', '', '', '' %}
            {%- set when = trig.split(';')[1] if ';' in trig else as_timestamp(now())|timestamp_custom('%Y-%m-%dT%H:%M:%S') %}
            {%- set status = trig.split(' /')[1] if ' /' in trig else 'n' %}
            {%- set status = status.split(';')[-2] if ';' in status else status %}
            {%- set triggerviz, previz, vizes = status, 'n', 0 %}
            {%- if states(ids) not in ('unavailable', 'none', 'unknown') %}
              {%- set who = states(ids) %}
              {%- if states[ids].last_changed not in ( 'none', 'unknown', 'unavailable') %}
                {%- set when = as_timestamp(states[ids].last_changed)|timestamp_custom('%Y-%m-%dT%H:%M:%S') %}
              {%- endif %}
            {%- endif %}
            {%- set width = states[idw].state if states[idw].state not in ( 'none', 'unknown', 'unavailable') else '' %}
            {%- set name = states[ids].name.split(' Browser')[-2] %}
            {%- set prev, dur = '', 0 %}
            {%- set usr  = who %}
            {%- if db[id] != undefined %}
              {%- set prev =  db[id].when if db[id].when != undefined else '' %}
              {%- set dur = db[id].for | int(0) if db[id].for != undefined else 0 %}
              {%- set usr  = db[id].user if db[id].user not in (undefined, null, '') else usr %}
              {%- set width  = db[id].width if db[id].width not in (undefined, null, '') else width %}
              {%- set previz =  db[id].status[0] if db[id].status != undefined else previz %}
              {%- set vizes =  db[id].vizes|int if db[id].vizes != undefined else vizes %}
              {%- set status = status~previz~' ' %}
              {%- set old = 'prev:' ~ db[id].prev ~ ' for:' ~ db[id].for ~ ' vizes:' ~ db[id].vizes ~ ' status:'~ db[id].status %}
            {%- endif %}
            {%- set inc = (as_timestamp(when, as_timestamp(now())) - as_timestamp(prev, 0)) | round(0) %}
            {%- if previz == 'v' and triggerviz in ('u','h') %}
              {%- set dur = max(dur + inc, 0) %}
              {%- set status = status~' +'~inc %}
            {%- endif %}
            {%- set vizes = vizes + 1 if triggerviz == 'v' else vizes %}
            {%- set new = {id: {'id': name, 'user': usr, 'prev': prev, 'when': when, 'for': dur, 'vizes': vizes, 'status': status, 'width': width, 'old':old }} %}
            {%- if previz=='n' or ('v' in (previz, triggerviz) and inc >= 1) %}
              {#- new record or was/is visible AND time has elapsed #}
              {{ dict(new, **others) }}
            {%- else %}
              {#- moving between hidden & unavailable OR <1 sec between triggers, leave the database unchanged #}
              {{ dict(db, **others) }}
            {%- endif %}
And the sensor used to trigger it:
  - sensor:
    - name: browser_users_last_state_viz
      unique_id: browser_users_last_state_viz
      state: >
         {% set lastone = states.sensor | selectattr('entity_id', 'search', '_browser_visibility$')| rejectattr('entity_id','contains','dji') | rejectattr('entity_id','contains','station') | sort(attribute='last_changed') | last | default %} {# #}
         {% set trig = lastone.entity_id.split('_browser')[-2].split('sensor.')[1] ~' /'~ lastone.state[0] ~';'~lastone.last_changed.isoformat()[0:19] if lastone and lastone.entity_id is not undefined else 'none' %}
         {{ trig }}
Not sure if you copied correctly but the ‘dict’ above lacks a ‘}’ at the end
Not sure I follow you - there are three dicts in the above YAML, all terminated with ’ }’ as far as I can see.
This lacks a closing }
Sorry, I was looking in the code! I just pasted a section of the database to save space, the whole thing does have }} at the end. Oops
