Hello together,
I fresh installed ESP Home but it seems to not work with installing or updating my esp devices.
I installed a bluetooth proxy with the website and it worked, but with ESP Home it always fails.
Here a example of my output, when I’m trying to update that bluetooth proxy esp device.
Output
Reading CMake configuration...
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is unknown
-- Found assembler: xtensa-esp32-elf-gcc
-- Warning: Did not find file Compiler/-ASM
-- Configuring incomplete, errors occurred!
See also "/data/build/atom-bluetooth-proxy-a05be4/.pioenvs/atom-bluetooth-proxy-a05be4/CMakeFiles/CMakeOutput.log".
See also "/data/build/atom-bluetooth-proxy-a05be4/.pioenvs/atom-bluetooth-proxy-a05be4/CMakeFiles/CMakeError.log".
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:298 (__project):
The CMAKE_C_COMPILER:
is not a full path and was not found in the PATH.
Tell CMake where to find the compiler by setting either the environment
variable "CC" or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
Call Stack (most recent call first):
CMakeLists.txt:3 (project)
The CMAKE_CXX_COMPILER:
xtensa-esp32-elf-g++
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
The CMAKE_ASM_COMPILER:
variable "ASM" or the CMake cache entry CMAKE_ASM_COMPILER to the full path
========================= [FAILED] Took 83.81 seconds =========================
= [ERROR] /config/esphome/atom-bluetooth-proxy-a05be4.yaml =
======================== [SUMMARY] ========================
- /config/esphome/atom-bluetooth-proxy-a05be4.yaml: FAILED
maybe i overlooked something but I didn’t find anything that seems to fix this issue.
