Help With ESP32/LD2410C
Can someone please tell me what I’ve gotten wrong in this code?
It’s a standard ESP32 WROOM I’m using and, using it as a BT proxy as well as trying to set up presence using an LD2410C based on the code here:
I can’t for the life of me work out where I’ve gone wrong after 2 hours staring at it! Everything shows up fine, just all entries show as “unavailable” or :unknown".
`substitutions:
friendly_name: Media Room ESP32
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/esp32-generic/esp32-generic.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: ********************************=
wifi:
ssid: !secret wifi_ssid
captive_portal:
uart:
tx_pin: 32
rx_pin: 33
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
uart_id: ld2410_uart
select:
  • platform: ld2410
    distance_resolution:
    name: distance resolution
    baud_rate:
    light_function:
    out_pin_level:
    name: out pin level
button:
  • platform: ld2410
    factory_reset:
    restart:
    query_params:
number:
  • platform: ld2410
    timeout:
    max_move_distance_gate:
    name: max move distance gate
    max_still_distance_gate:
    name: max still distance gate
    g0:
    move_threshold:
    name: g0 move threshold
    still_threshold:
    name: g0 still threshold
    g1:
    move_threshold:
    name: g1 move threshold
    still_threshold:
    name: g1 still threshold
    g2:
    move_threshold:
    name: g2 move threshold
    still_threshold:
    name: g2 still threshold
    g3:
    move_threshold:
    name: g3 move threshold
    still_threshold:
    name: g3 still threshold
    g4:
    move_threshold:
    name: g4 move threshold
    still_threshold:
    name: g4 still threshold
    g5:
    move_threshold:
    name: g5 move threshold
    still_threshold:
    name: g5 still threshold
    g6:
    move_threshold:
    name: g6 move threshold
    still_threshold:
    name: g6 still threshold
    g7:
    move_threshold:
    name: g7 move threshold
    still_threshold:
    name: g7 still threshold
    g8:
    move_threshold:
    name: g8 move threshold
    still_threshold:
    name: g8 still threshold
    light_threshold:
    name: light threshold
text_sensor:
  • platform: ld2410
    version:
    name: “presenece sensor version”
    mac_address:
    name: “presenece sensor mac address”
switch:
  • platform: ld2410
    engineering_mode:
    bluetooth:
    name: control Bluetooth
  • platform: ld2410
    moving_distance:
    name: “Moving distance (cm)”
    still_distance:
    name: “Still Distance (cm)”
    moving_energy:
    name: “Move Energy (%)”
    still_energy:
    name: “Still Energy (%)”
    detection_distance:
    name: “Distance Detection (cm)”
    g0:
    move_energy:
    name: g0 move energy
    still_energy:
    name: g0 still energy
    g1:
    move_energy:
    name: g1 move energy
    still_energy:
    name: g1 still energy
    g2:
    move_energy:
    name: g2 move energy
    still_energy:
    name: g2 still energy
    g3:
    move_energy:
    name: g3 move energy
    still_energy:
    name: g3 still energy
    g4:
    move_energy:
    name: g4 move energy
    still_energy:
    name: g4 still energy
    g5:
    move_energy:
    name: g5 move energy
    still_energy:
    name: g5 still energy
    g6:
    move_energy:
    name: g6 move energy
    still_energy:
    name: g6 still energy
    g7:
    move_energy:
    name: g7 move energy
    still_energy:
    name: g7 still energy
    g8:
    move_energy:
    name: g8 move energy
    still_energy:
    name: g8 still energy
    light:
binary_sensor:
  • platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
    type or paste code here
sorry, I thought Id’ done that.
substitutions:
packages:
esphome:
api:
  encryption:
    key: w9wiAZmZ1mYtIMThFvzEUCijXRNYoN2g8ik9AHluzmE=
wifi:
captive_portal:
uart:
  tx_pin: 32
  rx_pin: 33
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
select:
  - platform: ld2410
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
number:
  - platform: ld2410
    timeout:
    g0:
      move_threshold:
      still_threshold:
    g1:
      move_threshold:
      still_threshold:
    g2:
      move_threshold:
      still_threshold:
    g3:
      move_threshold:
      still_threshold:
    g4:
      move_threshold:
      still_threshold:
    g5:
      move_threshold:
      still_threshold:
    g6:
      move_threshold:
      still_threshold:
    g7:
      move_threshold:
      still_threshold:
    g8:
      move_threshold:
      still_threshold:
    light_threshold:
text_sensor:
  - platform: ld2410
    version:
      name: "presenece sensor version"
    mac_address:
      name: "presenece sensor mac address"
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
  - platform: ld2410
    moving_distance:
      name: "Moving distance (cm)"
    still_distance:
      name: "Still Distance (cm)"
    moving_energy:
      name: "Move Energy (%)"
    still_energy:
      name: "Still Energy (%)"
    detection_distance:
      name: "Distance Detection (cm)"
    g0:
      move_energy:
      still_energy:
    g1:
      move_energy:
      still_energy:
    g2:
      move_energy:
      still_energy:
    g3:
      move_energy:
      still_energy:
    g4:
      move_energy:
      still_energy:
    g5:
      move_energy:
      still_energy:
    g6:
      move_energy:
      still_energy:
    g7:
      move_energy:
      still_energy:
    g8:
      move_energy:
      still_energy:
    light:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
So everything shows up but is unknown?
What ESP32 chip are you using exactly? (What board/make/brand) You might have the wrong pins.
Thanks, you are correct, I changed the pins and it all sprung to life.
Typical, driving me nuts for hours and comes down a simple, silly error.
