Help with ESPHOME _ PipSolar PV Inverter
I bought a solar inverter this model: https://www.aliexpress.com/item/1005002605997074.html?spm=a2g0s.9042311.0.0.64624c4dd6dJoK.
I can connect to it with a USB cable.
I can also connect with EspHome (via HA) but the information is not updated.
What can I do with EspHome?
Try the following link for more information.
I am also interested in this,
can you please tell me that with exactly which ESP device you were able to connect it ?
Kind Regards
I.m use esp 32
Have you connected your Inverter via USB or UART or something else with ESP 32?
you need a rs232 to ttl convertor, like this: Placa de nível mini rs232 max3232 para ttl, módulo adaptador de nível 115200bps com 10 peças|Circuitos integrados| - AliExpress
Many thanks for the reply and sorry for not replying in time. I had corona virus, im ok now but have become weak.
Anyhow, I am going to order ESP32 and the rs232 to ttl converter. Can you please help in giving the pinouts.
I will also require some help in future I hope you dont mind that.
Best Regards,
of course …
I have configured my ESP32.
Can you please tell me that did you use MQTT or not ? Is MQTT necessary ?
And how did you create that card in Homeassistant? I am not able to see any entities of my inverter. Please do guide.
Many thanks
Go to Configuration> Devices & Services> Integrations
esphome:
  platform: ESP32
  board: esp32dev
# Enable logging
logger:
#  baud_rate: 0
# Enable Home Assistant API
api:
ota:
  password: "fcdc829ac919fca24e13186523b1a4e5"
wifi:
  ssid: "XXXXXXX"
  password: "YYYYY"
  manual_ip:
    static_ip: 192.168.100.32
    gateway: 192.168.100.1
    subnet: 255.255.255.0
  ap:
    ssid: "Tmk32 Fallback Hotspot"
    password: "cOFPRovpalmW"
captive_portal:
uart:
  - id: uart0
    tx_pin: GPIO16
    rx_pin: GPIO17
    # most devices use 2400 as baud_rate
    baud_rate: 2400
pipsolar:
  - uart_id: uart0
  - platform: pipsolar
    pipsolar_id: inverter0
    grid_rating_voltage:
    grid_rating_current:
    ac_output_apparent_power:
    ac_output_active_power:
    ac_output_voltage:
    ac_output_frequency:
    grid_voltage:
    grid_frequency:
    ac_output_rating_current:
    output_source_priority:
    charger_source_priority:
    topology:
    output_mode:
    output_load_percent:
    bus_voltage:
    inverter_heat_sink_temperature:
    pv_input_current_for_battery:
    pv_input_voltage:
    pv_charging_power:
    pv_power_balance:
    battery_rating_voltage:
    battery_recharge_voltage:
    battery_under_voltage:
    battery_bulk_voltage:
    battery_float_voltage:
    battery_type:
    battery_redischarge_voltage:
    battery_voltage:
    battery_charging_current:
    battery_capacity_percent:
    battery_discharge_current:
    battery_voltage_offset_for_fans_on:
Well I wasnt able to add it via that, I used MQTT and was able to add it. I have disconnected the Inverter at the moment so that is why it is not showing any readings. I will configure it later. Many thanks for your help.
I will play with it and will let you know if there is anything.
Best regards brother
Good day and thank you for your post.
Please be so kind and explain connection from TTL converter to Inverter cable.
Use cable provided with the inverter ? ( It has DB9 plug ) … Cut it open ?
Will give it a try, I experimented with Arduino sketch published some time ago and never managed to communicate with the inverter…
At the end , I managed to destroy the comm card of that particular inverter … ( my bad of course )
Thank you.
Greetings
Francisco
Hello, i have this cable that was included with the inverter. Is it necessary to have the converter, or i can use the female of this to the esp32? Eventually in with gpio i’ve to connected?
Thank you
Hi there,
If the cable is RS232, then you will need a converter.
Like the others, I used an RS232 to TTL converter from my cable. I’m not sure if your cable is exactly the same wiring so best to double check. The connectors I did as in the link.
https://powerforum.co.za/topic/10589-esphome-axpert-5k-rs232-pinout/
hello, yes the cable is RJ45 from the inverter (Axper MK IV) to RS232. I have this connector, https://www.amazon.it/gp/product/B07XSLV8GX/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
and i with to use instead of this https://www.amazon.it/Convertitore-Adattatore-Adattatori-Componenti-Elettronici/dp/B0B1D63X4V/ref=sr_1_4?keywords=rs232+to+ttl&qid=1668874853&qu=eyJxc2MiOiIyLjgwIiwicXNhIjoiMi41NSIsInFzcCI6IjEuMzcifQ%3D%3D&sr=8-4
After that i’m going to use a connector Rs232 female to the esp32
Hello, i have my sensor on pipsolar inverter working, but i wish to have a sensor to put in the dashboard of the Energy PV pannel, like in the picture.
Is there any sensor already done, in pipsolr to load, or i have to create one?
Thank you
hello, how I can i use a switch on home assistant, to send on/off to the inverter?
Hi, thanks for your share. What Is the PIN with green cable on es32? 3,3v side i mean.
me too, did you find a way?
I see a “current_max_ac_charging_current” variable.
Is there a way to change this values as needed, when needed?
for exemple, no more than 50% than “pv_input_current_for_battery”
