Help with eufy security add on disconnecting every few seconds and crashing and after update 2022.8
Can someone(@anon63427907) please help me with the following problem?
Off course I tried all the obvious:
rebooting
reinstalling the add on
ping is steady
The unit is connected with a wire.
The addon crasches since 2022.8
I don’t know for sure if the update to 2022.8 is related.
The system works for a while (form a few hours to a few days but never more than 2 days)
The system was rock solid before
I’ve enabled watchdog.
LOG
2022-08-22 10:50:45.268 INFO Eufy Security server listening on host 0.0.0.0, port 3000
2022-08-22 10:50:55.430 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 12050
2022-08-22 10:50:55.549 INFO Push notification connection successfully established
2022-08-22 10:51:03.441 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:51:08.485 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 14370
2022-08-22 10:51:16.583 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:51:21.630 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 29019
2022-08-22 10:51:29.654 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:51:34.700 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 21930
2022-08-22 10:51:42.743 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:51:47.780 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 24872
2022-08-22 10:51:55.847 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:52:00.883 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 17407
2022-08-22 10:52:08.891 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:52:13.932 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 24746
2022-08-22 10:52:21.975 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:52:27.009 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 18056
2022-08-22 10:52:35.083 INFO Disconnected from station T8010Pxxxxxxxx
2022-08-22 10:52:40.115 INFO Connected to station T8010Pxxxxxxxx on host 192.168.0.xx and port 25532
undefined:1
SyntaxError: Unexpected end of JSON input
at JSON.parse ()
at /usr/src/app/node_modules/eufy-security-client/build/push/client.js:207:38
at Array.forEach ()
at PushClient.convertPayloadMessage (/usr/src/app/node_modules/eufy-security-client/build/push/client.js:205:17)
at PushClient.handleParsedMessage (/usr/src/app/node_modules/eufy-security-client/build/push/client.js:154:43)
at PushClientParser. (/usr/src/app/node_modules/eufy-security-client/build/push/client.js:56:63)
at PushClientParser.emit (node:events:527:28)
at PushClientParser.onGotMessageBytes (/usr/src/app/node_modules/eufy-security-client/build/push/parser.js:137:14)
at PushClientParser.handleFullMessage (/usr/src/app/node_modules/eufy-security-client/build/push/parser.js:66:22)
at PushClientParser.waitForData (/usr/src/app/node_modules/eufy-security-client/build/push/parser.js:51:18)
Virtual Machine (HyperV) (6 core, 6GB, SSD)
Home Assistant 2022.8.6
Supervisor 2022.08.3
Operating System 8.5
Frontend-versie: 20220802.0 - latest
HomeBase 2 version 3.1.9.0h
subsystem 1.3.0.9
Can you please help me with this problem?
It seems like it is constantly disconnecting
I also rebooted the HomeBase
And please let me know if you need anything else.
Best Regards,
Sjoerd Beukers
Can you bring this into @bropat s attention through eufy-security-ws repository? I am following all the issues under it.
Thanks!
@bropat Can you please help me with this problem?
Thank you so much in advance!
Create an issue on GitHub, he is not an active home assistant user :slight_smile:
