I got 3 different entities involved in a fancoil-based heating/cooling system:
light.fancoil
: Zigbee 0-10v regulator connected to 0-10 terminals of the fancoil, to regulate the fan speed.
switch.onoff_fancoil
: Dry contact relay that controls on/off terminals of the fancoil
switch.valvula_fancoil
: Controls the on/off state of the water pipe that warms/cools the air
I ended up with this config that has 2 main issues:
It doesn’t trigger any of the switch entities when using the fan entity
When changing the speed in the fan entity, the ‘light.fancoil.brightness’ is updated to 0-49% only.
What am I doing wrong? I’ve already tried to use action
instead of service
, but nothing changed. I’m lost!
This is my yaml:
template:
- fan:
- name: "FanCoil Virtual"
unique_id: fancoil_virtual
state: "{{ is_state('light.fancoil', 'on') }}"
turn_on:
- service: switch.turn_on
entity_id:
- switch.onoff_fancoil
- switch.valvula_fancoil
- service: light.turn_on
entity_id:
- light.fancoil
turn_off:
- service: switch.turn_off
entity_id:
- service: light.turn_off
entity_id:
- light.fancoil
speed_count: 3
set_percentage:
- action: light.turn_on
entity_id: light.fancoil
brightness: "{{ percentage }}"
preset_modes:
- "off"
- "low"
- "medium"
- "high"
preset_mode: >
{% if is_state('light.fancoil', 'on') %}
{% if state_attr('light.fancoil', 'brightness') >= 130 %}
high
{% elif state_attr('light.fancoil', 'brightness') >= 20 %}
medium
{% else %}
low
{% endif %}
{% else %}
off
{% endif %}
set_preset_mode:
- choose:
- conditions:
- condition: template
value_template: "{{ preset_mode == 'off' }}"
sequence:
- service: fan.turn_off
entity_id: fan.fancoil_virtual
- conditions:
value_template: "{{ preset_mode != 'off' }}"
sequence:
entity_id:
brightness_pct: >
{% if preset_mode == 'high' %}
254
{% elif preset_mode == 'medium' %}
169
{% elif preset_mode == 'low' %}
84
{% else %}
0
{% endif %}
123
(Taras)
June 21, 2025, 1:44pm
2
If the light’s brightness
value is 150
, what will this report?
{% if state_attr('light.fancoil', 'brightness') >= 20 %}
high
{% elif state_attr('light.fancoil', 'brightness') >= 130 %}
medium
{% else %}
low
{% endif %}
HINT: It won’t report medium
Perhaps you meant to do this?
high
medium
{% else %}
low
{% endif %}
thanks for the reply, Taras.
In any case using the right values it doesn’t solve the percentage issue, as it still goes from 0 to 49%.
petro
(Petro)
June 21, 2025, 2:23pm
4
You need logic here to take 33 and convert it to low’s value, 66 for mediums value and 100 for highs value. And 0 for off. i.e.
{% if percentage == 33 %}
123
(Taras)
June 21, 2025, 2:36pm
5
What I pointed out is just one of several things wrong it (see petro’s post).
Thanks for your replies. I managed to set the “brightness” correctly by doing:
set_percentage:
brightness: "{{ (percentage * 254 / 100) | round(0) }}"
Now, I need to deal with the fact that is not acting over the 2 other switches, and I don’t know why…
123
(Taras)
June 21, 2025, 2:45pm
8
I am not certain this part is the correct way of handling the off
preset mode. Normally it should issue a command to turn off the controlled device(s) and its new status (now off
) is reported back to Template Fan (via its state
option). You’re turning off the Template Fan (fan.fancoil_virtual
) directly.
set_preset_mode:
- choose:
- conditions:
sequence:
NOTE
My comment is based on what I learned while automating a range hood fan .
EDIT
You need to (minimally) turn off light.fancoil
because that’s the entity you specified in the Template Fan’s state
option.
when setting a percentage, I need to turn on 2 different switches (switch.valvula_fancoil
and switch.onoff_fancoil
), and turning them off if the percentage is zero or the fan is in off
state.
petro
(Petro)
June 21, 2025, 2:51pm
10
Then you need to add those actions to the set percentage like you did for preset mode.
Thanks to your comments and some reading I ended up with a working config that I think is the most compact and self-contained:
template:
- fan:
turn_on:
entity_id: light.onoff_fancoil
- action: switch.turn_on
entity_id: switch.valvula_fancoil
turn_off:
- action: light.turn_off
- action: switch.turn_off
speed_count: 3
set_percentage:
- choose:
- conditions:
value_template: "{{ percentage == 0 }}"
sequence:
default:
Thanks @petro and @123 for your help! Hope this will help others when configuring fans with multi-device actions.
123
(Taras)
June 21, 2025, 3:46pm
12
If you’re interested, you can reduce the code to this:
template:
- fan:
turn_on:
- action: homeassistant.turn_on
entity_id:
- light.onoff_fancoil
turn_off:
- action: homeassistant.turn_off
entity_id:
speed_count: 3
set_percentage:
- if: "{{ percentage == 0 }}"
then:
entity_id:
else:
entity_id:
NOTE
I noticed that the only place where the Template Fan sets the value of light.fancoil
is in set_percentage
and only if percentage
is greater than zero.
Shouldn’t light.fancoil
also be set to off
when percentage
is zero? The state of light.fancoil
is used to determine the Template Fan’s state.
Or is light.onoff_fancoil
somehow related to light.fancoil
