Help with first blueprint - how to trigger when ANY light turns on, in an inputted target
I wonder if I’m asking something impossible or just can’t figure it out.
The goal is:
  • you select any # of lights
  • automation triggers when any of those lights turn on
What I’ve tried:
blueprint:
  name: Corey Motion Test
  description: Automate light with motion and timer.
  domain: automation
  input:
    target_lights:
      description: Multiple lights to keep in sync.
      selector:
          entity:
            domain: light
variables:
    light_data: !input light_data
    aux_motion_sensor: !input aux_motion_sensor
    target_lights: !input target_lights
    target_lights_are_on: "{{ expand(target_lights.entity_id) | selectattr('state', '==', 'on') | list | count > 0 }}"
trigger_variables:
  target_lights_are_on: "{{ target_lights_are_on }}"
  value_template: "{{ target_lights_are_on }}"
Template variable error: 'target_lights_are_on' is undefined when rendering '{{ target_lights_are_on }}'
Anyway to achieve this in a blueprint? Thanks a ton for any help!
The solution was to wait a few days and magically get an update to home-assistant (2022.4) that has multiple-entity select, which allows this request.
The input:
    target_lights:
      description:  The primary lights to be controlled
      selector:
        entity:
          multiple: true
The trigger:
# Light turned on
- platform: state
  entity_id: !input target_lights
  to: 'on'
  variables:
    should_start_timer: True
This is the same type of thing I am trying to do :wink:
