Help with fixing a Quirk TZE204_lpedvtvr (fixed)
I’m trying to build a custom quirk for a Moes Thermostat ( TZE204_lpedvtvr).
I found something similar to this thermostat as a TRV. I suppose it makes sense as the Thermostat itself looks like a TRV in a standard wall mount!
I just can’t get the HVAC Action sensor.
Anyhow, here’s my quirk - with some functions working:
"""Map from manufacturer to standard clusters for thermostatic valves."""
from typing import Any
from zigpy.profiles import zha
from zigpy.quirks.v2.homeassistant import PERCENTAGE, UnitOfTemperature, UnitOfTime
from zigpy.quirks.v2.homeassistant.binary_sensor import BinarySensorDeviceClass
from zigpy.quirks.v2.homeassistant.sensor import SensorStateClass
import zigpy.types as t
from zigpy.zcl.clusters.hvac import RunningState, Thermostat
from zhaquirks.tuya import TUYA_CLUSTER_ID
from zhaquirks.tuya.builder import TuyaQuirkBuilder
from zhaquirks.tuya.mcu import (
    DPToAttributeMapping,
    TuyaAttributesCluster,
    TuyaMCUCluster,
class TuyaThermostatSystemMode(t.enum8):
    """Tuya thermostat system mode enum."""
    Auto = 0x00
    Heat = 0x01
    Off = 0x02
class TuyaThermostatSystemModeV02(t.enum8):
    """Tuya thermostat system mode enum, auto and manual."""
    Auto = 0x00
    Manual = 0x02
class TuyaThermostatEcoMode(t.enum8):
    """Tuya thermostat eco mode enum."""
    Comfort = 0x00
    Eco = 0x01
class State(t.enum8):
    """State option."""
    Off = 0x00
    On = 0x01
class TuyaHysteresis(t.enum8):
    """Tuya hysteresis mode."""
    Comfort = 0x00
    Eco = 0x01
class TuyaPresetMode(t.enum8):
    """Tuya preset mode."""
    Eco = 0x00
    Auto = 0x01
    Off = 0x02
    Heat = 0x03
class TuyaThermostatV2(Thermostat, TuyaAttributesCluster):
    """Tuya local thermostat cluster."""
    _CONSTANT_ATTRIBUTES = {
        Thermostat.AttributeDefs.abs_min_heat_setpoint_limit.id: 500,
        Thermostat.AttributeDefs.abs_max_heat_setpoint_limit.id: 3000,
        Thermostat.AttributeDefs.ctrl_sequence_of_oper.id: Thermostat.ControlSequenceOfOperation.Heating_Only,
    def __init__(self, *args, **kwargs):
        """Init a TuyaThermostat cluster."""
        super().__init__(*args, **kwargs)
        self.add_unsupported_attribute(
            Thermostat.AttributeDefs.setpoint_change_source.id
            Thermostat.AttributeDefs.setpoint_change_source_timestamp.id
        self.add_unsupported_attribute(Thermostat.AttributeDefs.pi_heating_demand.id)
        # Previously mapped, marking as explicitly unsupported.
            Thermostat.AttributeDefs.local_temperature_calibration.id
            Thermostat.AttributeDefs.min_heat_setpoint_limit.id
            Thermostat.AttributeDefs.max_heat_setpoint_limit.id
class TuyaThermostatV2NoSchedule(TuyaThermostatV2):
    """Ensures schedule is disabled on system_mode change."""
    async def write_attributes(
        self,
        attributes: dict[str | int, Any],
        manufacturer: int | None = None,
        **kwargs,
    ) -> list:
        """Catch attribute writes for system_mode and set schedule to off."""
        results = await super().write_attributes(attributes, manufacturer)
        if (
            Thermostat.AttributeDefs.system_mode.id in attributes
            or Thermostat.AttributeDefs.system_mode.name in attributes
            tuya_cluster = self.endpoint.tuya_manufacturer
            await tuya_cluster.write_attributes({"schedule_enable": False})
        return results
    TuyaQuirkBuilder("_TZE204_lpedvtvr", "TS0601")
    # default device type is `SMART_PLUG` for this,
    # so change it back to keep UID/entity the same
    .replaces_endpoint(1, device_type=zha.DeviceType.THERMOSTAT)
    .tuya_dp(
        dp_id=2,
        ep_attribute=TuyaThermostatV2NoSchedule.ep_attribute,
        attribute_name=TuyaThermostatV2NoSchedule.AttributeDefs.running_state.name,
        converter=lambda x: RunningState.Heat_State_On if x else RunningState.Idle,
    .tuya_switch(
        dp_id=39,
        attribute_name="child_lock",
        translation_key="child_lock",
        fallback_name="Child lock",
    .tuya_dp(
        dp_id=1,
        attribute_name=TuyaThermostatV2NoSchedule.AttributeDefs.system_mode.name,
        converter=lambda x: {
            True: Thermostat.SystemMode.Heat,
            False: Thermostat.SystemMode.Off,
        }[x],
        dp_converter=lambda x: {
            Thermostat.SystemMode.Heat: True,
            Thermostat.SystemMode.Off: False,
        }[x],
    .tuya_dp(
        dp_id=16,
        attribute_name=TuyaThermostatV2NoSchedule.AttributeDefs.local_temperature.name,
        converter=lambda x: x * 10,
    .tuya_dp(
        dp_id=50,
        attribute_name=TuyaThermostatV2NoSchedule.AttributeDefs.occupied_heating_setpoint.name,
        dp_converter=lambda x: x // 10,
   .adds(TuyaThermostatV2NoSchedule)
   .tuya_number(
        dp_id=2,
        attribute_name="hvac_action",
        type=t.uint16_t,
        translation_key="hvac_action",
        fallback_name="HVAC Mode",
   .tuya_number(
        dp_id=34,
        attribute_name="max_temperature",
        type=t.uint16_t,
        unit=UnitOfTemperature.CELSIUS,
        min_value=15,
        max_value=35,
        step=1,
        multiplier=0.1,
        translation_key="max_temperature",
        fallback_name="Max temperature",
   .tuya_number(
        dp_id=18,
        attribute_name="min_temperature",
        type=t.uint16_t,
        min_value=1,
        max_value=15,
        step=1,
        multiplier=0.1,
        translation_key="min_temperature",
        fallback_name="Min temperature",
   .tuya_number(
        dp_id=48,
        attribute_name="display_brightness",
        type=t.uint16_t,
        min_value=1,
        max_value=100,
        step=1,
        translation_key="display_brightness",
        fallback_name="Display brightness",
   .tuya_number(
        dp_id=113,
        attribute_name="eco_temperature",
        type=t.uint16_t,
        min_value=5,
        max_value=30,
        step=1,
        multiplier=0.1,
        translation_key="eco_temperature",
        fallback_name="Eco temperature",
   .skip_configuration()
   .add_to_registry()
What I can’t work out is how to get the HVAC action setting - its under sensors in the screenshot here:
Any ideas?
Here are the ups:
  "1": "Switch",
  "2": "Work Mode",
  "16": "Current temperature",
  "18": "The lower limit of temperature",
  "28": "Factory data reset",
  "32": "Sensor selection",
  "34": "Set temperature ceiling",
  "39": "Child lock",
  "47": "State of the valve",
  "48": "Backlight brightness",
  "50": "Set temperature",
  "101": "Temp Calibration",
  "102": "Week Program 13 1",
  "103": "Week Program 13 2",
  "104": "Week Program 13 3",
  "105": "Week Program 13 4",
  "106": "Week Program 13 5",
  "107": "Week Program 13 6",
  "108": "Week Program 13 7",
  "109": "Floor temp.",
  "110": "Dead zone temp.",
  "111": "High protect temp.",
  "112": "Low protection temp.",
  "113": "Eco cool temp.",
  "114": "Screen Time Set",
  "115": "Rgblight"
and I’m getting these attributes:
whenever I turn the thermostat on or off from HA, I get the message shown at the bottom of the screen:
I got it working. Here’s the quirk - the only thing missing is schedules, which I’m not bothered about as I will use HA to handle that.
    TuyaMCUCluster,
class PresetMode(t.enum8):
    """Tuya preset mode  enum."""
    Manual = 0x00
    Temp_Manual = 0x01
    Programming = 0x02
    Eco = 0x03
class ScreenTimeSet(t.enum8):
    """Tuya screen time set enum."""
    Off = 0x00
    Short = 0x01
    Medium = 0x02
    Long = 0x03
class SensorMode(t.enum8):
    """Tuya sensor mode enum."""
    Air = 0x00
    Both = 0x01
    Floor = 0x02
    .adds(TuyaThermostatV2)
    .tuya_switch(
        dp_id=39,
    .tuya_dp(
        dp_id=47,
        ep_attribute=Thermostat.ep_attribute,
        attribute_name=Thermostat.AttributeDefs.running_state.name,
        converter=lambda x: RunningState.Idle if x else RunningState.Heat_State_On,
    .tuya_enum(
        dp_id=2,
        attribute_name="preset_mode",
        enum_class=PresetMode,
        translation_key="preset_mode",
        fallback_name="Preset mode",
    .tuya_dp(
        dp_id=1,
        ep_attribute=TuyaThermostatV2.ep_attribute,
        attribute_name=TuyaThermostatV2.AttributeDefs.system_mode.name,
        }[x],
        }[x],
    .tuya_dp(
        dp_id=16,
        attribute_name=TuyaThermostatV2.AttributeDefs.local_temperature.name,
    .tuya_dp(
        dp_id=50,
        attribute_name=TuyaThermostatV2.AttributeDefs.occupied_heating_setpoint.name,
    .tuya_number(
        dp_id=34 ,
        type=t.uint16_t,
        min_value=15,
        max_value=35,
        step=1,
        multiplier=0.1,
.tuya_number(
        dp_id=110,
        attribute_name="deadzone_temperature",
        type=t.uint16_t,
        min_value=0,
        max_value=5,
        step=1,
        translation_key="deadzone_temperature",
        fallback_name="Deadzone temperature",
 .tuya_switch(
        dp_id=28,
        attribute_name="factory_reset",
        translation_key="factory_reset",
        fallback_name="Factory reset",
 .tuya_switch(
        dp_id=115,
        attribute_name="rgb_backlight",
        translation_key="rgb_backlight",
        fallback_name="RGB Backlight",
    .tuya_number(
        dp_id=18,
        type=t.uint16_t,
        min_value=1,
        max_value=15,
        step=1,
        multiplier=0.1,
    .tuya_number(
        dp_id=48,
        type=t.uint16_t,
        min_value=1,
        max_value=100,
        step=1,
    .tuya_number(
        dp_id=113,
        type=t.uint16_t,
        min_value=5,
        max_value=30,
        step=1,
        multiplier=0.1,
    .tuya_number(
        dp_id=101,
        attribute_name=TuyaThermostatV2.AttributeDefs.local_temperature_calibration.name,
        type=t.int32s,
        min_value=-10,
        max_value=10,
        step=1,
        translation_key="local_temperature_calibration",
        fallback_name="Local temperature calibration",
    .tuya_enum(
        dp_id=32,
        attribute_name="temperature_sensor_select",
        enum_class=SensorMode,
        translation_key="sensor_mode",
        fallback_name="Sensor mode",
    .tuya_enum(
        dp_id=114,
        attribute_name="screen_time_set",
        enum_class=ScreenTimeSet,
        translation_key="screen_time_set",
        fallback_name="Screen Time",
    .tuya_number(
        dp_id=112,
        attribute_name="min_temperature_limit",
        type=t.uint16_t,
        min_value=1,
        max_value=30,
        step=1,
        multiplier=0.1,
        translation_key="min_temperature_limit",
        fallback_name="Min temp limit",
    .tuya_number(
        dp_id=111,
        attribute_name="max_temperature_limit",
        type=t.uint16_t,
        min_value=1,
        max_value=45,
        step=1,
        multiplier=0.1,
        translation_key="max_temperature_limit",
        fallback_name="Max temp limit",
    .tuya_number(
        dp_id=109,
        attribute_name="external_temperature_input",
        type=t.uint16_t,
        min_value=1,
        max_value=45,
        step=1,
        multiplier=0.1,
        translation_key="external_temperature_input",
        fallback_name="External temperature",
    .add_to_registry()
Thanks for the quirk. It works well.
May I know where to find those dp_id and the related definitions?
I actually found them looking through the Z2MQTT spec for the device
