Help with frigate notifications
Hi there, Im using the frigate notifications usign the blueprint Frigate Notifications v0.12.0.2.
I am trying to set it up that it will only send notifications when an alarm area is set (alarmo)
Right now, I have it setup with State Filter Entity (Optional) and have set my Alarm area as the entity. Then I added Triggered and Armed away to the State Filter States (Optional) section.
So in theory, only when the entity alarm.camera is in state Triggered or Armed away, then the Frigate notifications should be send. But its not working.
Any ideas?
alias: Camera Notify
description: ""
use_blueprint:
  path: SgtBatten/Stable.yaml
  input:
    camera: camera.boat
    notify_device: 1d0390853215562ed390721b52284fd6
    attachment: snapshot
    silence_timer: 10
    zone_filter: true
    state_filter: true
    state_entity: alarm_control_panel.camera
    state_filter_states:
      - Triggered
      - Armed away
Can’t you just make normal automation?
Trigger: armed away
Condition: camera state triggered
Really you’ll also need to get triggered camera so you know which snapshot to send but I may misunderstand your setup
Thanks for the reply,
I figured that the blueprint takes care of most of this for me,
I just need to enable and disable the blueprint using the Alarm control.
The blueprint works perfectly when it works, I just want the ability to disable the notifications.
Blueprint just creates automation correct?
SERVICES
automation.turn_off
automation.turn_on
Just turn the automaton off or on based on armed state
Hmm ok good idea, will give this a go.
Yea thanks this is working well now.
