Help with getting to configuration.yaml
hello guys, i am a complete newbie to hassio i have managed to install it onto the pi3 and i have home assistant which appears to be working when i go through the web based ui. i have downloaded samba and ssh server.
i can log into hassio with putty however that seems to be as far as i can get. i cannot see hassio amongst my network devices from my pc even though samba is running.
i am finding it hard to find good informative how too`s on this subject.
can anybody give me a point in the right direction please?
thanks, jamie.
p.s, here is the log from samba
account_policy_get: tdb_fetch_uint32_t failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32_t failed for type 10 (refuse machine password change), returning 0
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
STATUS=daemon ‘smbd’ finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.17.0.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 172.30.32.1
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.0.21
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.17.0.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 172.30.32.1
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.0.21
netbios connect: name1=HASSIO 0x20 name2=JAMIES-GAMING 0x0
netbios connect: local=hassio remote=jamies-gaming, name type = 0
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.17.0.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.17.0.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 172.30.32.1 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 172.30.32.1
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.0.21 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.0.21
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1
Samba name server HASSIO is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.21
become_local_master_browser: Awaiting potential browser state. Current state is 4
Could not find child 344 – ignoring
Could not find child 346 – ignoring
Could not find child 348 – ignoring
Could not find child 350 – ignoring
Could not find child 352 – ignoring
Could not find child 354 – ignoring
Could not find child 356 – ignoring
Could not find child 358 – ignoring
Could not find child 360 – ignoring
Could not find child 362 – ignoring
Could not find child 364 – ignoring
Could not find child 366 – ignoring
Could not find child 368 – ignoring
Could not find child 370 – ignoring
Could not find child 372 – ignoring
Could not find child 374 – ignoring
Could not find child 376 – ignoring
Could not find child 378 – ignoring
Could not find child 380 – ignoring
Could not find child 382 – ignoring
Could not find child 384 – ignoring
Could not find child 386 – ignoring
Could not find child 388 – ignoring
Could not find child 390 – ignoring
Could not find child 392 – ignoring
Could not find child 394 – ignoring
Could not find child 396 – ignoring
Could not find child 398 – ignoring
Could not find child 400 – ignoring
Could not find child 402 – ignoring
Could not find child 404 – ignoring
Could not find child 406 – ignoring
Could not find child 408 – ignoring
Could not find child 410 – ignoring
Could not find child 412 – ignoring
Could not find child 414 – ignoring
Could not find child 416 – ignoring
Could not find child 418 – ignoring
Could not find child 420 – ignoring
Could not find child 422 – ignoring
Could not find child 424 – ignoring
Could not find child 426 – ignoring
Could not find child 428 – ignoring
ok. i can find hassio on my sons computer in netrwork places but not my own. i cannot figure this out.
If you can log in with Putty, then you’ll find the configuration files in /config
You should be able to find Hass.io either at \\hassio.local or \\192.168.0.x (using the IP that you used for Putty if you didn’t use hassio.local
i have now managed to get to .yaml by installing the configurator and i can access it via UI.
however, back to putty, i type /config into the command and it says access denied.
Why/what do you want to config in hass.io with ‘/config’?
i don`t, just going by what tinkerer said. bare with me, i am a little clueless but im getiing there bit by bit. kind of on my own too lol
You’d need to type cd /config - maybe worth having a look here at the basics of the Linux command line.
thank you!
