I am trying to set external values for the presets that I have set in the climate control. I am only using the heating part.
I have setup the number helper and I can pull this into the control using the following yaml.
- platform: homeassistant
entity_id: input_number.garage_heater_home_setpoint
unit_of_measurement: "°C"
device_class: "temperature"
state_class: "measurement"
I want to dynamically change the preset value for the following:
preset:
- name: Home
default_target_temperature_low: 19 °C
mode: HEAT
where I want to change the 19 °C to be dynamically drive from the helper.
I have tried using lambda and jinja to do this but im a noob to HA and after 3 days of trying to figure it out I have to admit defeat on this.
can anyone help please?
