Hey everyone! I have a Yamaha AX-492 integrated amplifier that I’d like to control via IR with Home Assistant + Broadlink, but I no longer have the original remote. Does anyone have the IR codes for this model? Global Caché, Pronto hex or Broadlink Base64 format all work. Thanks! ![]()
I found this here.
It’s the closest thing I could find; not sure if the listed hex codes are useful for your application.
EDIT
There’s this resource but it doesn’t contain the AX-492.
You can also look here (yay! remotecentral is back online!).
Again, there’s no direct hit for AX-492, but there’s an entry for DSP-E492 on page 11. If that doesn’t totally match, try other models from the same era to fill in any missing or unresponsive commands.
