New Home Assistant user, I recently moved from Vera and so far so good! I could use a little help with an automation. I have a z-wave deadbolt (using keymaster) with a Aeotec recessed door sensor on my front door. My goal is form 22:00 to 06:30 everyday to have the door automatically lock after being closed for 5 minutes. I want the automation to make certain the door is closed before the lock is triggered. The automation I created only works if the door is open after 22:00 and I close it, if the door is already closed it does not work. If someone could offer up a solution I would be grateful. I would also like the door to relock if opened during the set time frame (which it currently does).
alias: Front Door Auto Lock 22:00
description: ""
- type: not_opened
platform: device
device_id: 5c91cb157ec1d329605dc48654262d31
entity_id: binary_sensor.front_door_sensor_sensor_state_any
domain: binary_sensor
for:
hours: 0
minutes: 5
seconds: 0
condition:
- condition: time
before: "06:30:00"
after: "22:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- device_id: 8676a6b95bb854c4847b83825588ce58
domain: lock
entity_id: lock.front_door_deadbolt
type: lock
mode: single
