Help with M-Bus USB slave Integration for Home Assistant on pi
I’m trying to connect an M-Bus Slave to USB module (link to the product: [M-Bus USB module on AliExpress
https://www.aliexpress.com/item/1005006205311636.html?spm=a2g0o.productlist.main.7.4ecd1f0cDu3cQe&algo_pvid=197624c0-268d-4562-ba2a-a2a83e4eae88&algo_exp_id=197624c0-268d-4562-ba2a-a2a83e4eae88-3&pdp_npi=4%40dis!NOK!90.33!84.57!!!56.95!53.32!%40211b61d017379953538043668ebaaa!12000036276070910!sea!NO!0!ABX&curPageLogUid=2zrnlLAXeb4x&utparam-url=scene%3Asearch|query_from%3A
to my Raspberry Pi 400 running Home Assistant and read data like kWh and that stuff from my meters. However, I am struggling to set it up properly and get the data into Home Assistant.
My Setup:
Device M-Bus Slave to USB module
Raspberry Pi 40 running Home Assistant
USB Port: The device shows up as /dev/serial/by-id/usb-Prolific_Technology_Inc._USB-Serial_Controller_CPBIb116L17-if00-port0 on the Pi
problem:
I cannot read any data from the M-Bus device and am unsure of how to properly configure Home Assistant to read values like kWh and Wh, and all of that, any suggestion on program / integration and how?
I would appreciate any advice or links to documentation that could help.
