Help with MariaDB recorder 'decimal.ConversionSyntax' error
Hi!
I wanted to try and setup a long term data storage database and found some guides on how to do it with influxDB but also how to setup mariaDB.
Home assistant v 2023.3.6 is in docker.
Both Maria & Influx got setup in docker.
influx works without a problem but HA seems to have some issues with Maria.
Cant find any information on this problem/errorcode that keeps occuring until timeout. Anyone that can help deciper where or help with what i should look at? Thanks.
Error during connection setup: [<class 'decimal.ConversionSyntax'>] (retrying in 3 seconds)
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 806, in _setup_recorder
    self._setup_connection()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1289, in _setup_connection
    Base.metadata.create_all(self.engine)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/schema.py", line 5581, in create_all
    bind._run_ddl_visitor(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3225, in _run_ddl_visitor
    with self.begin() as conn:
  File "/usr/local/lib/python3.10/contextlib.py", line 135, in __enter__
    return next(self.gen)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3215, in begin
    with self.connect() as conn:
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3251, in connect
    return self._connection_cls(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 145, in __init__
    self._dbapi_connection = engine.raw_connection()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3275, in raw_connection
    return self.pool.connect()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 455, in connect
    return _ConnectionFairy._checkout(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 1271, in _checkout
    fairy = _ConnectionRecord.checkout(pool)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 719, in checkout
    rec = pool._do_get()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 168, in _do_get
    with util.safe_reraise():
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 147, in __exit__
    raise exc_value.with_traceback(exc_tb)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 166, in _do_get
    return self._create_connection()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 396, in _create_connection
    return _ConnectionRecord(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 681, in __init__
    self.__connect()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 919, in __connect
    )._exec_w_sync_on_first_run(self.dbapi_connection, self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/event/attr.py", line 473, in _exec_w_sync_on_first_run
    self(*args, **kw)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/event/attr.py", line 487, in __call__
    fn(*args, **kw)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 1912, in go
    return once_fn(*arg, **kw)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/create.py", line 747, in first_connect
    dialect.initialize(c)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/dialects/mysql/base.py", line 2792, in initialize
    default.DefaultDialect.initialize(self, connection)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 478, in initialize
    self.server_version_info = self._get_server_version_info(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/dialects/mysql/base.py", line 2537, in _get_server_version_info
    cursor.execute("SELECT VERSION()")
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 206, in execute
    res = self._query(query)
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 321, in _query
    self._post_get_result()
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 355, in _post_get_result
    self._rows = self._fetch_row(0)
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/cursors.py", line 328, in _fetch_row
    return self._result.fetch_row(size, self._fetch_type)
decimal.InvalidOperation: [<class 'decimal.ConversionSyntax'>]
Followed by [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
Nvm. If anyone has a similar issue, the issues occurs with HA v 2023.3.6 but is solved in the newest one. v 2023.6
