Hi, this is my first post so please forgive me if I’m not in the right location to ask this.
I’ve been using Home Assistant for 2-3 years and Mosquitto broker for at least a year now with very minimal issues when it comes to updating. I’ve tried to install the latest update 6.5.0 a couple times now and every time I do, it fails to start. The error isn’t very descriptive and I’m not seeing any posts popping up with other people in the same boat.
- I am going from Mosquitto Broker 6.4.1 to 6.5.0.
- I’m using the default configuration.
- Every time I try to start the service I only get one line added to the logs. The error is “exec /init: input/output error”
Any assistance on whether or not this is a flawed update or there is something I need to do would be appreciated. Thank you.
- Is your install of Mosquito standalone (e.g. on a seperate server) or the HA Mosquitto Add-On?
- HAOS? Supervised? other?
- Any other “odd” signs? (ask in case of dreaded uSD card corruption disk issues)
Something sounds very wrong with the install - my HAOS broker has “just worked” for as long as I can remember. The logs just have the usual reconnections from the HA MQTT Integration:
025-02-08 13:05:31: New connection from 172.30.32.2:47502 on port 1883.
2025-02-08 13:05:31: Client <unknown> closed its connection.
Have you tried:
- Create a FULL backup, save to another device.
- Restore a backup ONLY of the broker:
- Try a different version of backup to restore?
- Try broker
at the bottom of the config page.
- Worst case, FULL backup again, then remove the broker Add-On, and install again.
Here’s a generic guide to setting up the MQTT broker and MQTT-native relevant add-ons which might help…:
Sonoff Tasmota fails to connect to MQTT - #3 by FloatingBoater
There’s some “hidden” config in the Mosquitto broker Add-On as HA creates credentials for HA internal connections (e.g. the MQTT integration) so I’m not sure if something might survive a re-install.
If this helps,
this post!
Hi, i just run into the same issue and was able to resolve it.
I had homeassistant running in a VM on a x86 host, then created a backup and migrated to homeassistant on a Raspberry Pi 4 (i used the ready-made image).
The issue “exec /init: input/output error” occured on “Mosquitto broker” and also on “Matter Server”.
My assumption was that maybe some x86 binary got migrated to arm which wouldn’t run. It turns out that both of these services use docker and it seems like this issue does indeed originates from something docker related.
After narrowing down that the supervisor is responsible for docker and after a bit of search for supervisor related docker things, i found that there is an option to repair “docker related issues”.
For me issue was gone when running “ha supervisor repair” using the “Terminal & SSH” Add-on.
Hope this helps the next person who finds this thread.
