Hi guys,
i’m evaluating HASS to replace my openHab setup (just used at the moment to interact with Google Assistant).
I don’t want for the moment to switch Z-Wave so i’ve installed MQTT module on Z-way, create a Mosquitto broker and published a Z-Wave switch.
On the HASS i’ve this setup:
switch:
platform: mqtt
state_topic: ‘zway/kitchen/leds/status’
command_topic: ‘zway/kitchen/leds/set’
payload_on: “on”
payload_off: “off”
optimistic: false
retain: true
I can power on the LED without problem, but it seems that HASS doesn’t understand the “state_topic” so the switch still remain in OFF state. If I use “optimistic: true”, i can power on/off the switch but without a real status update.
here is the log from HASS:
2018-06-24 17:47:46 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to zway/#
2018-06-24 17:47:46 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on zway/kitchen/leds: b’on’
2018-06-24 17:47:46 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on zway/kitchen/leds/set: b’on’
2018-06-24 17:47:48 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to zway/kitchen/leds/status
why there is “b” in front of the status?
How can i solve this issue?
My setup is currently running on Synology Docker, and version is 0.72.0
Thanks!
