i’ve been trying to create an mqtt sensor that populates data from an MQTT topic in an attribute. the sensor is relatively simple:
- name: "MQTT Persistent Global Variables"
unique_id: mqtt_persistent_global_variables
state_topic: "global_variables/mqtt_persistent_global_variables"
value_template: "{{ value_json.state }}"
json_attributes_template: "{{ value_json.vars }}"
the data in MQTT topic looks like this:
"state": "2024-12-16T21:21:23.850702-05:00",
"vars": {
"debounce_ac_temp_control": {
"timestamp": "2024-12-16T16:07:38.245043-05:00",
"value": 30
"debounce_tv_backlight_sync": {
"timestamp": "2024-12-16T16:28:36.324764-05:00",
"value": 180
"test1": {
"timestamp": "2024-12-16T21:13:50.395101-05:00",
"value": null
"test123": {
"timestamp": "2024-12-16T21:18:04.357604-05:00",
"value": 123
i’ve tried every combination i can think of for value_json
but none seem to populate the sensor attributes. the only attribute i get is the Friendly Name
. Here are some of the combinations that i’ve tried:
{{ value_json['vars'] }}
{{ value_json }}
i saw some people syaing you need to pipe them to_json, so i’ve tried all them with | to_json
as well. I also tried with just the value return, with same result. at this point i don’t know what else to try.
