I have 2 HA instances connected via VPN,
I have never worked with MQTT until now. I want to send sensor data from one HA instance to the other, i’m assuming the best way to do this will be via MQTT.
Any ideas how I can get started with this, the sensor is battery voltage.
MQTT Statestream
For this use case I would highly recommend the Remote Home Assistant integration GitHub - custom-components/remote_homeassistant: Links multiple home-assistant instances together
Much easier to configure.
Yea thanks, thats the route I took and its working well, it’s a shame as I really do need to learn MQTT haha.
Thanks for the sugestion.
