I think you can use the inject node to periodically inject into a current state node and get the values updated. Try the below inject node which will start automatically after NR deploy or Restart.
[{"id":"8e5d1f15.36cd2","type":"inject","z":"51045e07.bbf87","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1800","crontab":"","once":true,"onceDelay":"30","topic":"","payload":"Started!","payloadType":"str","x":200,"y":2400,"wires":[["cf644c9.7df87b","da48e0aa.6d9ba"]]},{"id":"cf644c9.7df87b","type":"api-current-state","z":"51045e07.bbf87","name":"input boolean","server":"d177950.2a5aa68","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":380,"y":2380,"wires":[[]]},{"id":"da48e0aa.6d9ba","type":"api-current-state","z":"51045e07.bbf87","name":"input boolean","server":"d177950.2a5aa68","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":380,"y":2440,"wires":[[]]},{"id":"d177950.2a5aa68","type":"server","name":"Home Assistant","legacy":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
