I’m trying to use Toggl with my home assistant automations. I’d like certain automations to trigger an API that starts time tracking. For example, if I sit down at my desk I have an automation that triggers and turns on my desk lamp. I’d also like that automation to start a “Studying” timer in Toggl.
But I’m having issues with getting the API to work correctly. I keep getting a 403 error, and I think it’s because my header is incorrect. Would someone mind taking a look and let me know if there’s something missing? The documentation has a !secret header file so it’s not of any help. Thanks!
(Note that the XXXXXXXX is substituted with my API key)
Unless it’s a copy & paste typo, the quote characters in your payload template are the wrong ones. You have the fancy slanted/curly quotes – “ and ‘ – and you need the “normal” ones – " and '.
Don’t know if that’s your problem, or only problem, but worth checking.
Is the -u the same thing that gets passed through with the authentication: part of the YAML? I’m just noticing that the -u is not part of the header, so wondering if that’s something different I need to consider.
Digging a little deeper I found this in their docs:
For HTTP Basic Auth you have to add the Authorization header with the request. The Authorization header is constructed as follows:
Username and password are combined into a string username:password or if you use the api token it should be combined xxxx:api_token (xxx indicating user’s personal token)
The resulting string literal is then encoded using Base64
The authorization method and a space i.e. "Basic " is then put before the encoded string.
For example, if the user agent uses ‘Aladdin’ as the username and ‘open sesame’ as the password then the header is formed as follows: Authorization: Basic QWxhZGRpbjpvcGVuIHNlc2FtZQ==
So you need to Base64 encode your xxxx:api_token string, and then pass that string with the Authorization: Basic header as shown above.
# Somebody did the initial work on a 'native' home assistant <-> toggle integration, but
# as of 2020-11-26, it's quite minimal; only a single 'time tracked all week' sensor.
# I need to be able to start and stop timers and, at present, the only way to do this with home assistant is
# with the native rest_command aka 'curl' integration. Each request is exposed to HA as a SERVICE
# which means I can create a generic request that can either start or stop a request based on
# the service data that is fed into it as the payload and URL fields support templating.
# See: https://www.home-assistant.io/integrations/rest_command/
# See: https://github.com/fredrikbaberg/ha-toggl/blob/47ef76dded1a547b0e00c549128e72a5c0d4a054/custom_components/toggl/sensor.py
# See: https://community.home-assistant.io/t/help-with-restful-api/92997/2
# See: https://github.com/toggl/toggl_api_docs/blob/43a7b7af20594b42945a1acffad066be05fc4e88/toggl_api.mds
# A 'generic' service to start or stop a toggle time entry
start_toggl_time_entry:
# The start endpoint uses POST
method: POST
# Always verify TLS cert!
verify_ssl: true
# This HA component has built in support for HTTP/Basic auth.
# The Toggle API docs are a bit weird about this, though.
# User name is your API token and password is the string `api_token` 😕 🤷
username: !secret toggl_api_token
password: "api_token"
# The API accepts only JSON requests.
# Please make sure you're setting Content-Type: application/json in your request header.
content_type: application/json
url: https://www.toggl.com/api/v8/time_entries/start
# See: https://github.com/toggl/toggl_api_docs/blob/43a7b7af20594b42945a1acffad066be05fc4e88/chapters/time_entries.md
# Fortunately, the project ID is pretty easy to discover. It's in the URL on the web interface
# E.G.: Go to the list of projects in your accouont and click on one, you'll be brought to
# a url like this: https://track.toggl.com/3123458/projects/112345626/team
# So the project is '112345626'
payload: '{"time_entry":{"description":"{{description}}","tags":["home_assistant"],"pid":{{pid}},"created_with":"home_assistant"}}'
# The Toggl API requires that you send along the exact time entity when making the STOP call.
# Unfortunately, there is no way for us to collect the ID of the created entity when we make the
# rest call above. The reply from the request is discarded unless there's an error; then, it's only logged.
# It may be possible to hack something together using actual `curl` and `jq` to parse out the entity ID and
# save the ID to a known location, but i'd rather fork the 'native' python extension that `fredrikbaberg`
# started and implement things 'properly'. So for now, we're just going to implement the START service.
# As 'work around', the toggl API seems to automatically stop the current / running time entity when a new
# one is created, so for most of the use-cases that I want to involve Home Assistant in, this behavior is
# actually advantageous.
And then you just call the rest_command.start_toggl_time_entry service with a few required parameters:
pid - the project ID the entity is meant to appear under
description - the description / title of the thing.
I can’t make any promises about my ability to fork / work on the initial integration from fredrikbaberg, but the above rest service should get any other lost internet souls started.
