### What happened?
After update to 1.30.2-1 Z2M starting, connects to configure…d Adapter, but fails to establish right protocol.
Skyconnect usb stick is connected with SiliconLabs Multiprotocol.
Z2M connects to.
port: tcp://core-silabs-multiprotocol:9999
adapter: ezsp
was working with previous version of Z2M
### What did you expect to happen?
Z2M connects successfully as in previous verion
### How to reproduce it (minimal and precise)
install 1.30.2-1, connect to SL Multiprotocol
### Zigbee2MQTT version
1.30.2
### Adapter firmware version
SLMultiprotocol 1.0.0
### Adapter
Skyconnect+SL Multiprotocol
### Debug log
[09:11:13] INFO: Preparing to start...
[09:11:13] INFO: Socat not enabled
[09:11:13] INFO: Zigbee Herdsman debug logging enabled
[09:11:13] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:debug 2023-03-04 09:11:14: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info 2023-03-04 09:11:14: Logging to console and directory: '/config/zigbee2mqtt/log/2023-03-04.09-11-14' filename: log.txt
Zigbee2MQTT:debug 2023-03-04 09:11:14: Removing old log directory '/config/zigbee2mqtt/log/2023-03-04.09-03-32'
Zigbee2MQTT:info 2023-03-04 09:11:14: Starting Zigbee2MQTT version 1.30.2 (commit #unknown)
Zigbee2MQTT:info 2023-03-04 09:11:14: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:debug 2023-03-04 09:11:14: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"ezsp","path":"tcp://core-silabs-multiprotocol:9999"}}'
2023-03-04T08:11:14.495Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"tcp://core-silabs-multiprotocol:9999","adapter":"ezsp"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2023-03-04T08:11:14.495Z zigbee-herdsman:adapter:ezsp:uart Opening TCP socket with core-silabs-multiprotocol:9999
2023-03-04T08:11:14.499Z zigbee-herdsman:adapter:ezsp:uart Socket connected
2023-03-04T08:11:14.499Z zigbee-herdsman:adapter:ezsp:uart Socket ready
2023-03-04T08:11:14.499Z zigbee-herdsman:adapter:ezsp:uart Uart reseting
2023-03-04T08:11:14.499Z zigbee-herdsman:adapter:ezsp:uart --> Write reset
2023-03-04T08:11:14.500Z zigbee-herdsman:adapter:ezsp:uart --> [1ac038bc7e]
2023-03-04T08:11:14.500Z zigbee-herdsman:adapter:ezsp:uart -?- waiting reset
2023-03-04T08:11:14.897Z zigbee-herdsman:adapter:ezsp:uart <-- []
2023-03-04T08:11:14.898Z zigbee-herdsman:adapter:ezsp:uart <-- [c1020b0a527e]
2023-03-04T08:11:14.898Z zigbee-herdsman:adapter:ezsp:uart <-- RSTACK: c1020b0a527e
2023-03-04T08:11:14.898Z zigbee-herdsman:adapter:ezsp:uart RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
2023-03-04T08:11:14.899Z zigbee-herdsman:adapter:ezsp:uart -+- waiting reset success
2023-03-04T08:11:14.899Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {"desiredProtocolVersion":4}
2023-03-04T08:11:14.899Z zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
2023-03-04T08:11:14.899Z zigbee-herdsman:adapter:ezsp:uart --> DATA (0,0,0): 00000004
2023-03-04T08:11:14.900Z zigbee-herdsman:adapter:ezsp:uart --> [004221a850ed2c7e]
2023-03-04T08:11:14.900Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2023-03-04T08:11:16.900Z zigbee-herdsman:adapter:ezsp:uart --> Error: Error: {"sequence":1} after 2000ms
2023-03-04T08:11:16.900Z zigbee-herdsman:adapter:ezsp:uart -!- break waiting (1)
2023-03-04T08:11:16.900Z zigbee-herdsman:adapter:ezsp:uart Can't send DATA frame (0,0,0): 00000004
2023-03-04T08:11:17.401Z zigbee-herdsman:adapter:ezsp:uart ->> DATA (0,0,1): 00000004
2023-03-04T08:11:17.401Z zigbee-herdsman:adapter:ezsp:uart --> [084221a850ef017e]
2023-03-04T08:11:17.401Z zigbee-herdsman:adapter:ezsp:uart -?- rewaiting (1)
2023-03-04T08:11:19.139Z zigbee-herdsman:adapter:ezsp:uart <-- []
2023-03-04T08:11:19.139Z zigbee-herdsman:adapter:ezsp:uart <-- [c1020b0a527e]
2023-03-04T08:11:19.139Z zigbee-herdsman:adapter:ezsp:uart <-- RSTACK: c1020b0a527e
2023-03-04T08:11:19.139Z zigbee-herdsman:adapter:ezsp:uart RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
2023-03-04T08:11:19.140Z zigbee-herdsman:adapter:ezsp:uart <-- [01]
2023-03-04T08:11:19.140Z zigbee-herdsman:adapter:ezsp:uart <-- [42a1a85e2805c0999c7e]
2023-03-04T08:11:19.140Z zigbee-herdsman:adapter:ezsp:uart <-- DATA (0,1,0): 0142a1a85e2805c0999c7e
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:uart --> ACK (1)
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:uart --> [8160597e]
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 0080000a021072
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":10,"stackType":2,"stackVersion":29200}
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:uart -+- rewaiting (1) success
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:uart -+- waiting (1) success
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:ezsp Switching to eszp version 10
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {"desiredProtocolVersion":10}
2023-03-04T08:11:19.141Z zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":10}
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart --> DATA (0,1,0): 01000100000a
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart --> [014321a9542a1fde467e]
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart <-- [8160597e]
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart <-- ACK (1): 8160597e
2023-03-04T08:11:19.142Z zigbee-herdsman:adapter:ezsp:uart -+- waiting (1) success
2023-03-04T08:11:20.140Z zigbee-herdsman:adapter:ezsp:uart <-- [a1443b7e]
2023-03-04T08:11:20.140Z zigbee-herdsman:adapter:ezsp:uart <-- NAK (1): a1443b7e
2023-03-04T08:11:20.141Z zigbee-herdsman:adapter:ezsp:uart NAK Unexpected packet sequence 1
2023-03-04T08:11:24.901Z zigbee-herdsman:adapter:ezsp:ezsp Time to watchdog ... 0
2023-03-04T08:11:24.901Z zigbee-herdsman:adapter:ezsp:ezsp ==> nop: null
2023-03-04T08:11:29.146Z zigbee-herdsman:adapter:ezsp:ezsp ==> {"_cls_":"nop","_id_":5,"_isRequest_":true}
2023-03-04T08:11:29.147Z zigbee-herdsman:adapter:ezsp:uart --> DATA (1,1,0): 0200010500
2023-03-04T08:11:29.147Z zigbee-herdsman:adapter:ezsp:uart --> [7d314021a9512a9a0d7e]
2023-03-04T08:11:29.147Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (2)
Zigbee2MQTT:error 2023-03-04 09:11:29: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-03-04 09:11:29: Failed to start zigbee
Zigbee2MQTT:error 2023-03-04 09:11:29: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-03-04 09:11:29: Exiting...
Zigbee2MQTT:error 2023-03-04 09:11:29: Error: Failure send version:{"type":"Buffer","data":[1,0,1,0,0,10]}
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:551:23
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
2023-03-04T08:11:29.167Z zigbee-herdsman:adapter:ezsp:uart <-- [1240a1a90c2a25bdf97e]
2023-03-04T08:11:29.167Z zigbee-herdsman:adapter:ezsp:uart <-- DATA (1,2,0): 1240a1a90c2a25bdf97e
2023-03-04T08:11:29.168Z zigbee-herdsman:adapter:ezsp:uart --> ACK (2)
2023-03-04T08:11:29.168Z zigbee-herdsman:adapter:ezsp:uart --> [82503a7e]
2023-03-04T08:11:29.168Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 028001580030
2023-03-04T08:11:29.168Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x58: {"_cls_":"invalidCommand","_id_":88,"_isRequest_":false,"reason":48}
2023-03-04T08:11:29.168Z zigbee-herdsman:adapter:ezsp:uart -+- waiting (2) success
