Help with Sonoff ZBMINIL2
Hi there,
I have bought 4 pieces from this device. I want to make traditional switches smart.
In my living room I have two lamps a ceiling and a wall lamp.
I have one device paired to my zigbee zha network long time ago, maybe one year. This is working fine. I can wiring it to the wall lamp or the ceiling lamp, both worked as expected.
So I wiring the second device the same way to the ceiling or wall lamp as the working example, but I’m unable to pair it to zha. I have tested all three devices, non is able to pair. All devices start after enable power to flash slowly the green LED, but zha doesn’t find something. There is a lamp from the kitchen beside which is also a zigbee router, less than 1m away.
So I tried to only wiring L in and L out in hope the devices can pair, but without success. Now I need a new idea…
Is there another way to test if the devices working correctly? Maybe a way that I can use a socket to test?
I have never had problems with my zigbee network, but maybe I can use a socket method and test it on the other side of the apartment.
Thanks in advance
Micha
I have put some work in my zigbee network.
  1. Coordinator Firmware update
  2. Zigbee and wlan channel separation
Now the zigbee pairing worked fine.
Micha
