Help with switch please
HI all,
I have been trying to create a simple switch that will call a aREST to switch on another switch on another harware device on the LAN but for the life of me, I cannot get it to show up in the front end - here is what I have in my configuration.yaml file:
switch:
  - platform: arest
    resource: http://192.168.0.x/json.htm&command=On
Anyone have any idea why this is not showing up? I have checked for duplicates and logs, and nothing showing…
Is it showing up in the dev-states page?
If it is then all you need to do is add it to a card/badge in the ui.
Hi finity,
Unfortunately it does not show up in the Dev/States page at all, rebooted and nothing - I have found that when I reboot, the aREST call is being made and then noting shows in HA GUI.
No errors in config whatsover.
Any thoughts?
OK, found the solution with some serious help from the community - you know who you are and I am very grateful!
So, what I have been trying to do is to call a HTTP request when switch on a switch (REST or aREST), but meanwhile back at the ranch I have been requesting the STATUS of a switch with REST/aREST. Totally the wrong way round, so, to resolve this, here is what I have done and it works a treat:
Objective: Create a switch on the main UI to, when turned on, call a HTTP request and the switch the switch off. I use it in a scene, so, turn scene on, then toggle UI as off.
Reason: I have a Domoticz switch on another device (about 4 years old), that turn on a GPIO, turns on a motor to close a curtain for 7 seconds and then switch itself off. (yeah, yeah, I need to replace it with a new HASSIO Pi_Zero)
Logic: Works for me, not logic at all
Solution: Create a rest_command in configuration.yaml file, create an automation using a input_boolean
Code: (the formatting has gone a wee bit squiffy - somehow the editor and code blocks does not apply, check spacing)
[config\congiguration.yaml] Add the following:
rest_command:
my_request:
url: http://192.168.0.1:8080/json&whateverawsomecommandgoeshere
(congiguration.yaml includes this:)
input_boolean: !include_dir_merge_named input_boolean
automation: !include_dir_merge_list automations
[config\input_boolean\curtain.yaml] Add the following:
studycurtain:
initial: off
[config\automations\curtain.yaml] Add th e following:
- id: AutomationNumber001
alias: ‘StudyCurtain’
- platform: state
entity_id: input_boolean.studycurtain
to: ‘on’
- service: rest_command.my_request
- service: input_boolean.turn_off
This works for me - hope that this will help someone else trying to create a switch to call a HTTP request when switched on.
