Help with template sensor! comparing two numbers
Hey everyone!
I am trying to create a sensor that shows if my desktop is actively being used.
I integrated it into HA through IOT Link which gives me a sensor that shows the Idle time of the PC.
So far so good. I am trying to get a sensor that is on when the idle time (in seconds) is under 900. The sensor should be off when it is over.
This is what I have:
    sensors:
      desktop_pc_active:
        friendly_name: 'Desktop PC active'
        value_template: >-
            {% set desktop = states('sensor.desktop_oaf62lp_system_idle_time') | float %}
            {% if desktop < 900 %} On
            {% else %} Off
            {% endif %}
It works as intended however the state of the sensor is saved as a string I suppose. So it just has “on” or “off” in it. I would like the sensor to be on or off, so it reflex the status also in lovelace. Does that make sense?
Anyone that can help me?
Cheers!
You mean you want a template binary sensor?
yes! exactly!
So you want a binary sensor?
Then make a template binary sensor
    sensors:
      desktop_pc_active:
        value_template: >-
            {{  states('sensor.desktop_oaf62lp_system_idle_time') | float < 900 }}
Why was that so hard for me to figure out… Thanks a lot mate!
