Help with Template Switches
I’m hoping someone can help me understand what I’m doing wrong with a Switch Template I’m trying to create. Here is my YAML:
template:
  - switches:
    - garage_door_controller1:
        name: "Garage Door Controller 1"
        default_entity_id: garage_door_controller1
        value_template: "{{ is_state('cover.garage_door_controller1', 'open') }}"
        turn_on:
          service: cover.open_cover
          entity_id: cover.garage_door_controller1
        turn_off:
          service: cover.close_cover
After a restart, I am going to Developer Tools → States and the entity doesn’t show up. What am I doing wrong?
TIA
The example you posted is not following the structure described in the documentation for the Template Switch integration.
Specifically, these two lines are invalid.
  - switches:
Try this version.
template:
  - switch:
      - name: "Garage Door Controller 1"
        state: "{{ is_state('cover.garage_door_controller1', 'open') }}"
        turn_on:
        turn_off:
That line is also invalid, it needs a full entity ID:
default_entity_id: switch.garage_door_controller1
Template - Common Configuration Options
template:
  - switch:
        turn_on:
          - action: cover.open_cover
        turn_off:
          - action: cover.close_cover
